07-20-2018, 23:09 | #1 (permalink) |
Freak Poster Join Date: Jan 2005 Location: KOLKATA Age: 51
Member: 102582 Status: Offline Thanks Meter: 72 | Lenovo P2a42 showing "Boot Charger Loop" ? One Lenovo P2a42 model showing "BOOT CHARGER LOOP" on the screen always. Not charging properly at all. Always blinking "100%" on the charger symbol on the right top corner? I have already Wiped Cache data and wiped everything but the problem is not resolved? Is this Software or Hardware issue ? Awaiting for the perfect solution? BR, amit |
07-21-2018, 05:41 | #2 (permalink) |
Member: 163 Status: Offline Thanks Meter: 7,785 | Charging problem can hardly be caused by software ... time to disassemble phone, check usb connector (replace if needed), follow usb +5v line, check for shortings etc. Also, battery may be faulty, keep that in mind. b.r. Alex
__________________ Always press THANKS button if my post was helpful! Please DO NOT send me PM's for help, You can ask for help on forum Do not post THANKS posts - use thanks button ! ALWAYS use SEARCH button before posting! |
The Following User Says Thank You to Brka For This Useful Post: |
07-21-2018, 07:27 | #3 (permalink) |
Member: 102582 Status: Offline Thanks Meter: 72 | First time, I disassembled the phone completely and took the voltage measurement on the Battery Connector. USB ampere also showing ampere 1.11! Then it might be the issue of battery? |
