Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Lenovo > Lenovo Hardware Repair
Old 04-15-2019, 15:36   #1 (permalink)
Member: 2368235
Lenovo P780 Encryption Failed [S_DL_PMT_ERR_NO_SPACE] eMMC / Hardware Problem !!!
Hi, I dont know is this hardware or software failure?
I tried to find for solution but no avail.
Out of the sudden phone shows this message as in the picture attached: Encryption failed
I didnt flash it or make any kind of changes, it worked OK prior to this.
When I press "Resset Device" nothing happens. I am stuck in that screen.
When I press volume up, I have this Menu in chinese. I dont know what can I choose from that Menu in order to fix it?
Is there any way to fix this phone by flashing it or some other way?
Old 04-15-2019, 22:03   #2 (permalink)
Moderator
Brka's Avatar
Member: 163
Thanks Meter: 5,886
Okay,
very simply: While in factory menu (with Chinese letters),
scroll down to row where is written ##eMMC,
press power button on it and wait for finish, phone will restart.
If you still encounter same message ... definatly eMMC (Flash Memory) problem.
b.r.
Alex
__________________
Always press THANKS button if my post was helpful!
Please DO NOT send me PM's for help, You can ask for help on forum
Do not post THANKS posts - use thanks button !
ALWAYS use SEARCH button before posting!
Old 04-16-2019, 00:30   #3 (permalink)
Member: 2368235
Thanks, I did that, phone restarted immediately and now it is stuck on Logo screen.
Nothing is changing.
Old 04-16-2019, 01:22   #4 (permalink)
Moderator
Brka's Avatar
Member: 163
Thanks Meter: 5,886
try enter recovery via key combo (power off/reset then hold volume up button),
and do wipe from recovery.
If still the same ... answer is obvious.
p.s. If you decide to flash it - DO NOT flash preloader in any case.
b.r.
Alex
__________________
Old 04-16-2019, 11:50   #5 (permalink)
Member: 2368235
Hi, hot to do "wipe from recovery"?
is that some of this items in chinese Menu, on the picture? do you know which one? I tried some of them earlier and nothing happened.
thanks
Old 04-16-2019, 12:58   #6 (permalink)
Member: 2368235
nevermind, I find out so will try now
It took a long time and didnt boot after wipe, so I guess it didnt fixed it.
I think I have to try to flash,
I find out how to use sp flashtool, only thing I dont know about that scatter file? should I download it, and where?
Old 04-16-2019, 17:17   #7 (permalink)
Member: 2368235
Update:
I tried to flash, after a lot of search I find the right SP_Flash_Tool and flash (LiFe_v07), but at the and I got
Message: BROM ERROR : S_DL_PMT_ERR_NO_SPACE (5069)
is this means that is a hardware error? is it emmc chip?
Old 04-16-2019, 17:36   #8 (permalink)
Moderator
...:::::NP™:::::...'s Avatar
Member: 1162626
Sonork: 100.1591727 QQ:2337938173
Thanks Meter: 9,525
Yes it's hardware problem mean eMMC partition is destroyed or corrupted.
__________________
Use Search Button to get Instant Result | Follow Forum Rules
Avoid Spams in the forum to prevent ban your account.
The Following User Says Thank You to ...:::::NP™:::::... For This Useful Post:
Old 04-19-2019, 19:10   #9 (permalink)
Member: 2368235
For that kind of malfunction, is that some chip that can be removed and replaced (like RAM in PC) or has to be done with soldering?
Old 04-19-2019, 20:52   #10 (permalink)
Moderator
Brka's Avatar
Member: 163
Thanks Meter: 5,886
It is flash memory chip, soldered on board, usually glued. It is not user-replaceable.
Skills needed to replace : very advanced / high.
b.r.
Alex
__________________
Page generated in 0.17382 seconds with 7 queries
