Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > BlackBerry (RIM) > BlackBerry Android Based Devices
BlackBerry Android Based Devices General Android phones discussion, firmwares, solution, root, help
Old 03-22-2018, 08:43   #1 (permalink)
lastmile's Avatar
Member: 2482400
Sonork: 100.1677259
Thanks Meter: 115
Blackberry Keyone FRP solutions
Blackberry Keyone FRP remove
fklash this file : https://mega.nz/#!7INQEKyJ!juIv4YOwr...IZnWXOQru4NHso
after :
Go to Vision Settings
Enable Talkback
Make L shape
Select talk back settings
Select Help and feedback
Select "Get started with voice access"
Tap on the youtube video to open youtube
in youtube, minimize the video and tap top right corner
Select privacy policy
In chrome, search for quick shortcut maker
Download it from apkmirror and install it by enabling installation from unknown sources
In the quick shortcut maker, open the the activity by BlackBerry Setup Wizard that ends with OOBEExitActivity
Now you can go to Settings and do a Factory Reset.
youtub link:https://www.youtube.com/watch?v=kIQNJZkJ6ko
The Following 5 Users Say Thank You to lastmile For This Useful Post:
Old 06-15-2018, 14:31   #2 (permalink)
Member: 2162899
One has the unknown sources disabled and the other with disabled keyboard both touch and buttons what can i do
Old 07-05-2018, 19:45   #3 (permalink)
Member: 179453
Thanks Meter: 29
thanks but didn't work.. thank you my phone is in fast boot mode already and it doesn't do nothing.. only in fast boot.
Old 07-26-2018, 18:52   #4 (permalink)
Member: 1787478
Thanks Meter: 22
if I downgrade from newest firmware , can I brick phone or it's an secured operation ?
thanks
Old 09-11-2018, 15:24   #5 (permalink)
Member: 1110430
Thanks Meter: 104
after :
Enable Talkback
Make L shape
This file just brick my blackberry keyone. is there any other way to remove frp?
The Following User Says Thank You to Dzelailai For This Useful Post:
Old 09-15-2018, 09:11   #6 (permalink)
Member: 1084045
Thanks Meter: 41
here you have a video tutorial by me when unknown source is grey out.
http://www.youtube.com/watch?v=R_SVLF2cGqY
The Following 2 Users Say Thank You to pogradecar1 For This Useful Post:
Old 09-17-2018, 02:08   #7 (permalink)
Member: 1110430
Thanks Meter: 104
January security file bricked my phone after flash.What may be the reason?.My phone is sprint.Pls help to remove the frp as unknown source is still gray out.
Old 10-02-2018, 11:48   #8 (permalink)
Member: 1110430
Thanks Meter: 104
pls anybody i am still waiting for solution to solve this problem.The unknown source is gray out and if i flash the January security the phone will brick. Pls help.
Old 10-10-2018, 10:40   #9 (permalink)
Member: 2085623
Thanks Meter: 221
Here is a tutorial how bypass Blackberry with Android OS 8.1 and security patch from 09-2018. Tested on Blackberry Key2 with last system update.
Google Account verification, Factory Reset Protection, Google Account protection bypass tutorial for Blackberry phones on Android 8.x OS by Hardreset.info Team
http://www.youtube.com/watch?v=zp-V8WiLaOc
The Following 5 Users Say Thank You to m1serwis For This Useful Post:
Old 10-13-2018, 15:55   #10 (permalink)
Member: 1110430
Thanks Meter: 104
pls can this solve unknown sources gray out?
Old 10-16-2018, 14:48   #11 (permalink)
Moderator
Member: 1139057
Sonork: 100.109924
Thanks Meter: 4,428
Yes man solution is for all new Blackberry that unknown source is gray out do you read manual ?
__________________
Please do not Personal Message me for help or troubleshooting. They will be ignored. Use the forums!
To get Instant help use "search" & follow "sticky thread"..!!!
By respecting/following forum rules,You will be respected .!
The Following User Says Thank You to wgmmmx1 For This Useful Post:
Old 10-25-2018, 05:06   #12 (permalink)
Member: 2630561
unknown sources hidden. I need solution. Thanks you!
The Following User Says Thank You to anhphamip For This Useful Post:
Old 10-26-2018, 10:38   #13 (permalink)
Member: 2771307
Thanks Meter: 772
You got a solution in a movie do you watch it?
IMEI.info Team
The Following User Says Thank You to IMEI_info For This Useful Post:
Old 10-30-2018, 11:43   #14 (permalink)
Member: 2871973
This tutorial worked for me. Thanks a lot.
The Following User Says Thank You to ebusmaximus For This Useful Post:
Old 11-05-2018, 11:41   #15 (permalink)
Member: 686560
Thanks Meter: 68
https://tclota.birth-online.de worked for me samle
The Following User Says Thank You to serpas007 For This Useful Post:
Page generated in 0.23621 seconds with 8 queries
