BlackBerry Android Based Devices General Android phones discussion, firmwares, solution, root, help |
02-10-2018, 13:12 | #1 (permalink) |
Freak Poster Join Date: May 2014 Location: Dhaka Bangladesh Age: 34
Member: 2179298 Status: Offline Sonork: 100.1660353.Aslam Thanks Meter: 215 | Blackberry BBB100-7 FRP Lock Fast i Try This Method..... 1. Startup priv 2. Connect to wifi 3 when priv shows checking connection then immediately it shows software update switch of router to stop connection with the priv 4 hit next till u get to the setup pattern screen, setup a pattern lock then restart phone 5 when phone restarts phone will be locked with the pattern u setup earlier. 6 launch the dialer button from th locked screen and dial *#*#4636#*#* to enter secret menu. 7 hit on usage statistics 8 hit on the back button and u will find yourself in settings 9 scroll down to backup and reset 10 reset phone and when phone starts up, setup a new device. That's it But Not Work.................. I need............Help How To Remove FRP........ Thanks In Advance.......... |
The Following 4 Users Say Thank You to aslam hossain For This Useful Post: |
02-11-2018, 15:45 | #2 (permalink) | |
Freak Poster Join Date: Dec 2007
Member: 664247 Status: Offline Thanks Meter: 371 | Quote:
How to Bypass Frp BlackBerry KEYone BBB100 android 7 | |
The Following User Says Thank You to himcom For This Useful Post: |
02-12-2018, 08:01 | #3 (permalink) |
Member: 2179298 Status: Offline Sonork: 100.1660353.Aslam Thanks Meter: 215 | YES Bro......... i Also tri this method...... |
The Following 3 Users Say Thank You to aslam hossain For This Useful Post: |
02-20-2018, 07:44 | #5 (permalink) |
No Life Poster Join Date: Jan 2015 Location: Narsingdi, Dhaka, Bangladesh Age: 28
Member: 2325851 Status: Offline Sonork: 100.1680491 Thanks Meter: 2,363 | sir i have a blackberry bbb100-2 phone google account problem what can be done in such a way? |
The Following User Says Thank You to pintu_das For This Useful Post: |
03-03-2018, 20:32 | #7 (permalink) |
Junior Member Join Date: Mar 2017
Member: 2698861 Status: Offline Thanks Meter: 5 | Go to Vision Settings Enable Talkback Make L shape Select talk back settings Select Help and feedback Select "Get started with voice access" Tap on the youtube video to open youtube in youtube, minimize the video and tap top right corner Select privacy policy In chrome, search for quick shortcut maker Download it from apkmirror and install it by enabling installation from unknown sources In the quick shortcut maker, open the the activity by BlackBerry Setup Wizard that ends with OOBEExitActivity Now you can go to Settings and do a Factory Reset. |
The Following 3 Users Say Thank You to futuretechuk For This Useful Post: |
07-19-2018, 14:48 | #8 (permalink) |
No Life Poster Join Date: Jul 2002 Location: Tanzania
Member: 14229 Status: Offline Thanks Meter: 135 | Go to Vision Settings Enable Talkback Make L shape Select talk back settings Select Help and feedback Select "Get started with voice access" Tap on the youtube video to open youtube in youtube, minimize the video and tap top right corner Select privacy policy In chrome, search for quick shortcut maker Download it from apkmirror and install it by enabling installation from unknown sources In the quick shortcut maker, open the the activity by BlackBerry Setup Wizard that ends with OOBEExitActivity Now you can go to Settings and do a Factory Reset. unknown sources not highlighted. can not accept. security patch 5 may 2018. any idea? |
The Following User Says Thank You to calvinpower For This Useful Post: |
08-02-2018, 03:52 | #9 (permalink) | |
No Life Poster Join Date: Dec 2008
Member: 930280 Status: Offline Thanks Meter: 1,183 | Quote:
08-07-2018, 16:03 | #10 (permalink) |
Freak Poster Join Date: Aug 2014 Location: algeria
Member: 2232889 Status: Offline Thanks Meter: 91 | no just do a factory reset than when it starts connect it to a wifi set as new device let t check for account than it will give you to skip the account and thats it all good |
The Following 2 Users Say Thank You to AnonDz For This Useful Post: |
08-11-2018, 11:50 | #12 (permalink) | |
No Life Poster Join Date: Oct 2017
Member: 2766801 Status: Offline Thanks Meter: 182 | Quote:
Any solution friends, i have exact same problem, unknown sources not highlighted /or it grayed, security patch 5 may 2018. Any solution pls | |
