Blackberry BBB100-7 FRP Lock Blackberry Android Phone Model ( BBB100-7 ) FRP Lock Fast i Try This Method..... 1. Startup priv 2. Connect to wifi 3 when priv shows checking connection then immediately it shows software update switch of router to stop connection with the priv 4 hit next till u get to the setup pattern screen, setup a pattern lock then restart phone 5 when phone restarts phone will be locked with the pattern u setup earlier. 6 launch the dialer button from th locked screen and dial *#*#4636#*#* to enter secret menu. 7 hit on usage statistics 8 hit on the back button and u will find yourself in settings 9 scroll down to backup and reset 10 reset phone and when phone starts up, setup a new device. That's it But Not Work..................:confused: I need............Help How To Remove FRP........ http://i65.tinypic.com/2qar5hj.jpg Thanks In Advance.......... |
How to Bypass Frp BlackBerry KEYone BBB100 android 7 |
YES Bro.........:eek: i Also tri this method...... |
same problem plz solve this problem |
sir i have a blackberry bbb100-2 phone google account problem what can be done in such a way? |
Same Problem Please How To Solve it Need Solution Method |
Go to Vision Settings Enable Talkback Make L shape Select talk back settings Select Help and feedback Select "Get started with voice access" Tap on the youtube video to open youtube in youtube, minimize the video and tap top right corner Select privacy policy In chrome, search for quick shortcut maker Download it from apkmirror and install it by enabling installation from unknown sources In the quick shortcut maker, open the the activity by BlackBerry Setup Wizard that ends with OOBEExitActivity Now you can go to Settings and do a Factory Reset. |
Go to Vision Settings Enable Talkback Make L shape Select talk back settings Select Help and feedback Select "Get started with voice access" Tap on the youtube video to open youtube in youtube, minimize the video and tap top right corner Select privacy policy In chrome, search for quick shortcut maker Download it from apkmirror and install it by enabling installation from unknown sources In the quick shortcut maker, open the the activity by BlackBerry Setup Wizard that ends with OOBEExitActivity Now you can go to Settings and do a Factory Reset. unknown sources not highlighted. can not accept. security patch 5 may 2018. any idea? |
Hi Any solution for 7.1.1 frp please? |
Any solution friends, i have exact same problem, unknown sources not highlighted /or it grayed, security patch 5 may 2018. Any solution pls |
