Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > BlackBerry (RIM) > BlackBerry Android Based Devices
BlackBerry Android Based Devices General Android phones discussion, firmwares, solution, root, help
Old 02-10-2018, 13:12   #1 (permalink)
aslam hossain's Avatar
Member: 2179298
Sonork: 100.1660353.Aslam
Thanks Meter: 215
Blackberry BBB100-7 FRP Lock
Blackberry Android Phone Model ( BBB100-7 ) FRP Lock
Fast i Try This Method.....
1. Startup priv
2. Connect to wifi
3 when priv shows checking connection then immediately it shows software update switch of router to stop connection with the priv
4 hit next till u get to the setup pattern screen, setup a pattern lock then restart phone
5 when phone restarts phone will be locked with the pattern u setup earlier.
6 launch the dialer button from th locked screen and dial *#*#4636#*#* to enter secret menu.
7 hit on usage statistics
8 hit on the back button and u will find yourself in settings
9 scroll down to backup and reset
10 reset phone and when phone starts up, setup a new device. That's it
But Not Work..................
I need............Help
How To Remove FRP........
Thanks In Advance..........
The Following 4 Users Say Thank You to aslam hossain For This Useful Post:
Old 02-11-2018, 15:45   #2 (permalink)
Member: 664247
Thanks Meter: 371
1. Startup priv
2. Connect to wifi
maybe you can try this method
How to Bypass Frp BlackBerry KEYone BBB100 android 7
The Following User Says Thank You to himcom For This Useful Post:
Old 02-12-2018, 08:01   #3 (permalink)
Member: 2179298
Thanks Meter: 215
YES Bro.........
i Also tri this method......
The Following 3 Users Say Thank You to aslam hossain For This Useful Post:
Old 02-17-2018, 06:25   #4 (permalink)
Member: 2641193
Sonork: 100.1675747
Thanks Meter: 4
same problem plz solve this problem
Old 02-20-2018, 07:44   #5 (permalink)
pintu_das's Avatar
Member: 2325851
Sonork: 100.1680491
Thanks Meter: 2,363
sir i have a blackberry bbb100-2 phone google account problem
what can be done in such a way?
The Following User Says Thank You to pintu_das For This Useful Post:
Old 02-20-2018, 15:55   #6 (permalink)
shahinbangla's Avatar
Member: 2318480
Sonork: 100.1669259
Thanks Meter: 198
Same Problem Please How To Solve it Need Solution Method
Old 03-03-2018, 20:32   #7 (permalink)
Member: 2698861
Thanks Meter: 5
Go to Vision Settings
Enable Talkback
Make L shape
Select talk back settings
Select Help and feedback
Select "Get started with voice access"
Tap on the youtube video to open youtube
in youtube, minimize the video and tap top right corner
Select privacy policy
In chrome, search for quick shortcut maker
Download it from apkmirror and install it by enabling installation from unknown sources
In the quick shortcut maker, open the the activity by BlackBerry Setup Wizard that ends with OOBEExitActivity
Now you can go to Settings and do a Factory Reset.
The Following 3 Users Say Thank You to futuretechuk For This Useful Post:
Old 07-19-2018, 14:48   #8 (permalink)
calvinpower's Avatar
Member: 14229
Thanks Meter: 135
Enable Talkback
Make L shape
unknown sources not highlighted. can not accept.
security patch 5 may 2018.
any idea?
The Following User Says Thank You to calvinpower For This Useful Post:
Old 08-02-2018, 03:52   #9 (permalink)
CHANDARAKK's Avatar
Member: 930280
Thanks Meter: 1,183
Enable Talkback
Make L shape
any idea?
unknown source not allow i have the same problem any idea how to remove frp or can i downgrad it safe?
Old 08-07-2018, 16:03   #10 (permalink)
AnonDz's Avatar
Member: 2232889
Thanks Meter: 91
no just do a factory reset than when it starts connect it to a wifi set as new device let t check for account than it will give you to skip the account and thats it all good
The Following 2 Users Say Thank You to AnonDz For This Useful Post:
Old 08-09-2018, 13:23   #11 (permalink)
Member: 457765
Thanks Meter: 77
Hi
Any solution for 7.1.1 frp please?
Old 08-11-2018, 11:50   #12 (permalink)
successnbd's Avatar
Member: 2766801
Thanks Meter: 182
Enable Talkback
Make L shape
any idea?
Any solution friends, i have exact same problem, unknown sources not highlighted /or it grayed, security patch 5 may 2018.
Any solution pls
Old 08-12-2018, 03:33   #13 (permalink)
CHANDARAKK's Avatar
Member: 930280
Thanks Meter: 1,183
i dont think easy as u said for BB
The Following User Says Thank You to CHANDARAKK For This Useful Post:
Old 08-12-2018, 11:37   #14 (permalink)
AnonDz's Avatar
Member: 2232889
Thanks Meter: 91
I unlocked one just the day I posted my reply and it’s as easy as that
Old 08-15-2018, 02:40   #15 (permalink)
CHANDARAKK's Avatar
Member: 930280
Thanks Meter: 1,183
no i can not boot to setting i need wipe reset do know how to do hard reset?
Page generated in 0.22638 seconds with 8 queries
