Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > BlackBerry (RIM) > BlackBerry Android Based Devices
BlackBerry Android Based Devices General Android phones discussion, firmwares, solution, root, help
Old 03-23-2019, 06:54   #1 (permalink)
atv
Member: 109335
Thanks Meter: 27
Frp bbb100-2
FRP KEYone BBB100-2
PRD-63117-015 -AAK8799 AAL6822 AAM4811 AAN3588 AAO4722 AAP6388 AAQ3022 AAT166 AAV119 AAW377 AAY819 ABA693 ABG044 ABG366 ABJ879 ABL693 ABP819
Hi, I have a Keyone BBB100-2 frp locked, proof of purchase and invoice because is an imported phone, but a 10 year old girl, used a google account and reset, she doesn’t remember as she claims, and there is no service center in my country, the original version was ABG366, I downgraded it to AAK8799, but result white led blinking, so I flashed then ABA693, with no errors, and phone booted fine, but the Talkback version remained the same v5.21, then I flashed AAW377 ok, but same outcome, then I flashed AAQ3022, no errors, but in the first flash, speaker with noice, second time everything ok, but same talkback version in all flashed autoloaders, and the problem is that when you use the L method, and help, search voice, it gives you only text no youtube option, I managed to get through a browser but with no javascript enabled so I can search, but you tube, maps, or else, freezes, and if try to login in browser or download, freezes as well because no javascript enabled, is there any other option to unlock or bypass FRP with no talkback access,
1.- already tried to put in EDL mode, no success
2. tried the SIM card pin method, but no notification at home screen
3.-Tried receiving a call method, but when dialer is on there is no action after *#*#4636#*#*
4.- tried the message push with hushsms.apk, no notification of message
5.- no box, tool or fastboot option
any guide appreciated
Old 03-23-2019, 07:11   #2 (permalink)
atv
Member: 109335
Thanks Meter: 27
tried *#*#46368676#*#*, phone info and usage but after back, only the call in course, all of this codes, but didn't found an option to browse
Calendar. *#*#225#*#*
Debug info for Google Play Service. *#*#426#*#*
Access Google Partner Setup. *#*#759#*#*
Access email debug information. *#*#36245#*#*
Old 06-01-2019, 08:24   #3 (permalink)
Abussabah's Avatar
Member: 412813
Sonork: 100.1594692
Thanks Meter: 353
here is your solution
https://www.youtube.com/watch?v=iIEtbd_Uvjo
with required files
The Following User Says Thank You to Abussabah For This Useful Post:
Page generated in 0.22112 seconds with 10 queries
