How To Fix Blackberry Z10 STL100-1,2,3,4 Antitheft Protection Autoloader Part 1 Autoloader Part 2 Autoloader Part 3 Autoloader Part 4 Autoloader Part 5 Download all the above autolader files from part 1 to part 5 Use 7zip to extract the autoloader file above First Steps Extract the fifth autoloader file above In it there are two files First and Second autolader Turn off the z10 blackberry and click the First autolader file The process will run and finish Turn on your z10 blackberry The first step of your blackberry is still locked Second Steps Click Second autoloader Connect the z10 blackberry to the computer The process will automatically run Finish and turn it on Now your z10 blackberry is not locked anymore The app is still not full and use Darcy's Blackberry tool Done For more details check here Thanks For GREENSOFT SMART |
or the mos simple way to remove any bb id you check here. |
thank its working.. pass : z10stl100-1 |
how to solved? |
