10-22-2018, 07:25 | #1 (permalink) |
Junior Member Join Date: Aug 2018
Member: 2857683 Status: Offline Thanks Meter: 9 | How to repair iPhone 7 Black Screen iPhone 7 boot with no display, but the boot is current normal. if Screen replacing also cannot solve the problem,We can draw the conclusion that the logic board backlight circuit broke down.We provide some repair methods |
The Following User Says Thank You to Serio hou For This Useful Post: |
12-06-2018, 08:19 | #4 (permalink) |
Freak Poster Join Date: Aug 2018 Location: China
Member: 2861866 Status: Offline Thanks Meter: 71 | There have some steps about to repair iPhone 7 black screen as following: Step 1: Take out the logic board. The test grounding resistance value of J4502 – normal value. Which shows that backlight circuit is also normal. Yet backlight signal is connected directly with backlight IC U3701. Step 2: Apply some BGA Paste Flux, take down the backlight IC with Hot Air Gun at 320 degrees. Step 3: Clean the tins with Soldering Iron and then clean again with PCB Cleaner Step 4: Apply some BGA Paste Flux. Align the backlight IC to the right place and solder it with Hot Air Gun at 320 degrees. Step 5: Once the logic board is cooling enough, clean it with PCB Cleaner. Step 6: Assemble the phone and test. The phone boots normally with screen display—fault cleared |
