03-20-2017, 21:58 | #1 (permalink) |
Junior Member Join Date: Jan 2014 Location: usa
Member: 2117977 Status: Offline Thanks Meter: 1 | how to transform contacts from andriod to ios 10.2.1 any software or solution that can be worked ? please help me |
The Following User Says Thank You to mrh2470 For This Useful Post: |
03-20-2017, 22:48 | #2 (permalink) | |
No Life Poster Join Date: Aug 2006 Location: Free Palestine
Member: 330579 Status: Offline Thanks Meter: 67,512 | Quote:
You can use Google account for transfer from Android to IOS any version. How to Sync Your Old Contacts to iPhone | |
04-13-2017, 17:59 | #7 (permalink) |
Junior Member Join Date: Oct 2010
Member: 1428808 Status: Offline Thanks Meter: 3 | easiest way i always use is the application called copy my data It will make a hotspot to connect to. You can even transfer media like videos and fotos. Or simply copy them to your simcard and import on ios. |
The Following User Says Thank You to aprate For This Useful Post: |
05-15-2017, 03:07 | #8 (permalink) |
Junior Member Join Date: Nov 2016
Member: 2647001 Status: Offline Thanks Meter: 1 | There are a couple of apps you can use for contacts transfer: https://support.apple.com/en-us/HT201196 https://www.tunesbro.com/transfer-co...o-android.html |
The Following User Says Thank You to talveoli For This Useful Post: |
05-15-2017, 12:41 | #10 (permalink) | |
No Life Poster Join Date: Oct 2013 Location: MajeedGsm
Member: 2046498 Status: Offline Sonork: 100.1676751 Thanks Meter: 162 | hello you can do that Quote:
always press:> GSM-Forum - Search Forums before post Follow the rules. http://forum.gsmhosting.com/vbb/f62/...rules-1591101/ BestRegards, MajeedGsm. | |
05-21-2017, 13:40 | #11 (permalink) |
Junior Member Join Date: May 2017
Member: 2719293 Status: Offline Thanks Meter: 2 | You have to first export contacts from your android phone. When you are done with it then you have to import it on your iPhone. If you are having problem contact Apple support. |
07-24-2017, 10:32 | #12 (permalink) |
Junior Member Join Date: Jul 2016
Member: 2593076 Status: Offline Thanks Meter: 1 | You can consider a free third-party app, such as ApowerTrans, to transfer contacts from Android to iOS. You do not need to bother with the computer, just phone to phone transfer. It is very quick and easy. You can give it a try! |
08-10-2017, 03:22 | #13 (permalink) |
Junior Member Join Date: Jul 2017
Member: 2735073 Status: Offline Thanks Meter: 0 | I personally use ApowerTrans. You may use it too. This tool is used to transfer files from one phone to another in a very fast way. Step 1: Install the file on both Android and iOS phone. Step 2: Pair the devices by clicking the dock-like icon on the interface of the tool. You may just tap the icon on your Android phone. Step 3: it will detect your iPhone. tap on the iPhone icon and the devices will be paired. Step 4: Check all the contacts that you want to transfer and then click "Send". |
