10-08-2017, 14:51 | #1 (permalink) |
Junior Member Join Date: Oct 2017
Member: 2765867 Status: Offline Thanks Meter: 0 | Iphone 7 Boot loop I came across a series of problems with an Iphone I recently purchased. Well, I repair Iphones, but only the simple stuff. So i bought this Iphone 7 that had a shattered screen and that was lagging and had an issue with the home button. Homebutton is clicking multiple times when you click it. Except that, it works fine. I updated to Ios11 and boom...boot loop. I dug around and replaced some ribbon cables, displays, did some recoveries and found out that it would only boot up when I leave the proximity flex unplugged. It will take about 5 minutes to boot, but eventually it comes back to life. Another thing I discovered is that voice record was not working. I read somewhere that this could indicate a PCB problem. Next thing was the freezing. It works like a champ and lag free until i try to open an app, does not matter which. It will freeze for a few seconds. I also found out that the guy i bought it from tried to repair it himself, lost some screws and the flex brackets. Well, I hope that some of you guys can help me. I really hit a wall here. |
10-09-2017, 11:18 | #4 (permalink) |
Member: 2765861 Status: Offline Thanks Meter: 6 | Yea, impossible to return to 10.3.3 now :/ - Try an other LCD (if you have an OEM screen restore the phone with this screen attached) - Voice recording problem and freezing may also be a audio IC issue. You'll have to check this chip located at the back on the motherboard, near the Nand chip. Reheat for 1 minute, try. If it works, reball or change the audio IC. |
The Following User Says Thank You to ProfesseurLouis For This Useful Post: |
03-23-2018, 08:46 | #6 (permalink) |
Freak Poster Join Date: Feb 2011
Member: 1518920 Status: Offline Thanks Meter: 16 | If someone else have similar issue I give you the solution of this problem https://www.youtube.com/watch?v=bQMaqHXGlO8&t=339s |
The Following 3 Users Say Thank You to karmellino For This Useful Post: |
09-27-2018, 06:43 | #8 (permalink) |
No Life Poster Join Date: Sep 2016
Member: 2621291 Status: Offline Thanks Meter: 124 | Here is a useful playlist with only iPhone repairs, you can learn from it: https://www.youtube.com/playlist?lis...MYkLalUJQkbDnA |
The Following User Says Thank You to eselekt For This Useful Post: |
