Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > iPhone ,iPod & iPad (Apple Inc. Products) > iPhone, iPad, iPod Hardware Repair
iPhone, iPad, iPod Hardware Repair Hardware Repair discussions for iPhone, iPod , iPad & Apple Products, help, guides.
Old 05-21-2018, 07:40   #1 (permalink)
MR.MAMUN's Avatar
Member: 548479
Thanks Meter: 138
iphone 7 camera flash light not wirking?
iphone back camera front camera flash light not working ?latest iso install but same problme.how o polem solve?
Old 05-25-2018, 14:21   #2 (permalink)
Member: 1062732
Thanks Meter: 23
try change power swicth...
The Following User Says Thank You to CEELCOM For This Useful Post:
Old 05-30-2018, 05:38   #3 (permalink)
Member: 2575005
Thanks Meter: 41
I have an iPhone 7 that did not charge, I changed the U2 and the charge already works but the rear camera and the flash or flashlight does not work. You could help me thanks
Enviado desde mi iPhone utilizando Tapatalk
Old 06-03-2018, 09:54   #4 (permalink)
Member: 1989771
try replace your flash ????
Old 07-02-2018, 17:55   #5 (permalink)
Member: 2309595
Thanks Meter: 112
Change back camera. The flash light will work again.
The iPhone 7 have very bad issue with back camera/flashlight and big Audio codec
Old 07-02-2018, 19:31   #6 (permalink)
Member: 2327477
Thanks Meter: 2
i had such problem and it was fixed by changing the light on the back
Old 07-03-2018, 16:34   #7 (permalink)
Member: 2562692
Sonork: 100.1679408
Thanks Meter: 51
iPhone 7 rear camera problem circuit testing voltage
see this videos .........................
https://www.youtube.com/watch?v=7cw9qN-1u80
Old 07-24-2018, 07:53   #8 (permalink)
Member: 1911098
Thanks Meter: 16
In my case replacing the power button/volume keys flex cable solved the problem.
Old 07-25-2018, 08:02   #9 (permalink)
Member: 2562692
Sonork: 100.1679408
Thanks Meter: 51
try this one ....http://forum.gsmhosting.com/vbb/f100...-done-2436929/
Old 10-01-2022, 10:40   #10 (permalink)
Member: 3014633
To solve the iphone 7 camera flashlight not working, you are supposed to check out a few things that might be the reason for this issue. You can check and see if your iPhone is covered with an opaque cover, which means that the flashlight's lens is not visible. Make sure that the iPhone covers and make sure that it is not blocking the flashlight. If it is blocking the flash, you need to remove it as this can be one of the major reasons of iphone flashlight not working here. You can also restart your device to resolve the issue. A simple restart can solve many errors with your iPhone. You can just navigate to settings > General > Shut Down. Give your iPhone one minute, then start it again.
Old 12-02-2022, 20:47   #11 (permalink)
Member: 2749507
Sonork: 33333
Thanks Meter: 6
check your both camera first...if its working than go with measure pins
Page generated in 0.19368 seconds with 9 queries
