05-20-2019, 09:13 | #1 (permalink) |
Junior Member Join Date: Dec 2011 Location: Greece Age: 49
Member: 1708510 Status: Offline Thanks Meter: 2 | iphone 7 drain fast & only charges by fake cables I suspect charging IC 610... Any opinions or experience please? Thanks in advance |
The Following User Says Thank You to skoubri For This Useful Post: |
05-23-2019, 08:18 | #7 (permalink) |
Member: 1708510 Status: Offline Thanks Meter: 2 | Hello all, thanks for your answers.. @.:softbank:. you mean tristar (U2?)… or U4001? which is the correct ref number? / @toni_85 swi lines check? I am not sure how to... for any shorts you mean? Also an update, thinking that it cannot recognize genuine apple cable, I thought that normally should have problem to recognize accessories too like headphones etc.. But not.. genuine headphones AND headphone adapter to 3.5mm jack works also as expected. Also found a very old genuine cable from my iPhone 5 which worked too!!! I am totally confused! Only problem seems to be the draining battery which goes down to 1% from 100 in a couple of hours or more (3-4 max)… I could use it for two days without recharging... I also considered to replace the battery for starting point but as I know batteries do not die I suddenly.. The phone doesn't have a single scratch and have been never opened... this is why I am hesitating to start the procedure of replacing tristar but as it seems this is my only hope.. |
