02-14-2018, 11:28 | #1 (permalink) |
Freak Poster Join Date: Sep 2012 Location: Loading! Age: 34
Member: 1813502 Status: Offline Sonork: 100.1623430 Thanks Meter: 182 | Iphone 7 error 14 problem I got Iphone 7 stuck in recovery mode and when I m restoring it is giving error 14. Once again I tried with DFU mode but same error. |
02-26-2018, 15:54 | #2 (permalink) |
Junior Member Join Date: Apr 2017
Member: 2709277 Status: Offline Thanks Meter: 2 | I came across this problem as well. swapped out all the sensors, then put the affected motherboard into a known working iphone 7Plus body and same thing unable to restore properly. Still got the same itunes error 14. this might mean that something on the board itself is damaged? I do a bit of micro soldering but not the best at spotting faults on the microscopic level yet.... |
02-27-2018, 19:13 | #3 (permalink) |
Freak Poster Join Date: Nov 2017 Location: Canada
Member: 2777379 Status: Offline Thanks Meter: 34 | Error 14 is Corrupted Software, So it's usually related with the NAND flash, try updating your iPhone with the latest beta iOS on 3uTools, or try on the most updated iTunes version. If nothing then ensure you've tried a different charging cable and charging port. If this cannot be fixed via Software then you may need to reprogram the NAND and replace it on the board, then you would proceed to redo all those above steps but it's very rare the NAND would turn out to be faulty depending on whether or not the iPhone has had repair attempts done on it or had an impact/water damage |
02-28-2018, 05:02 | #4 (permalink) |
Crazy Poster Join Date: May 2017 Location: shenzhen
Member: 2713523 Status: Offline Thanks Meter: 15 | Solution #1: Reboot your iPhone Solution #2: Check Out the Faulty Cable/Port Solution #3. Is Wi-Fi Network Working Properly? Solution #4: Repair You need the professional iPhone repair tools to repair your iPhone. |
03-12-2018, 10:43 | #6 (permalink) |
Junior Member Join Date: Dec 2017
Member: 2791754 Status: Offline Thanks Meter: 0 | hi, guys actually i got asus zen phone max it came for frp i tride but i didnt do that,i havent seen the frp video also.but what i did is i went to xda firmware from there i ve downloaded the file for max i copied that file in sd card and i ve used that file from recovery after rebooting phone it got "DEAD" now its shows only 9008 usb driver apart from that nothing working...... please help me with this problem what can i do i am not getting any thing plz help.... |
07-25-2018, 08:00 | #10 (permalink) |
Insane Poster Join Date: Apr 2016 Location: india
Member: 2562692 Status: Offline Sonork: 100.1679408 Thanks Meter: 51 | hi error 14 iphone 7 need to open cpu and rebol after fixed be care full cpu open not Easy and check battery same time battery problem ...thanks |
07-26-2018, 00:13 | #11 (permalink) |
Insane Poster Join Date: Sep 2013
Member: 2018487 Status: Offline Thanks Meter: 2 | history of this phone is that i just updated the software after that stuck on apple logo but can still be connected to pc..so thought it was the audio ic.. reball audio ic and make jumper but still the same stuck on apple logo.. so i decided to restore the phone that comes up wth error 14. any help plss?? |
