11-21-2019, 04:04 | #16 (permalink) |
Insane Poster Join Date: Jan 2018
Member: 2797527 Status: Offline Thanks Meter: 4 | 1. Use the USB cable that came with your device. If you don't have it, try a different Apple USB cable. 2. Switch to a different USB port on your computer. Don't plug into your keyboard. 3. Switch to a USB port on a different computer. 4. If you still see the error, check for other USB issues, check your third-party security software, then check your hardware. BTW, it's also advisable to Mac iPhone system recovery to check whether there is software issue with your device and have a further repair. |
03-03-2020, 03:26 | #17 (permalink) |
Junior Member Join Date: Sep 2018
Member: 2865098 Status: Offline Thanks Meter: 2 | Hi, When your iPhone is stuck in the recovery mode or DFU mode, or your recovery/DFU mode is not working, you can try using a third-party professional iOS repair software to help you. It's capable of repairing various iOS issues like iOS stuck problems, black screen, white screen, iOS update failure. More importantly, it will not put you in a risk of losing any data on your device. |
