Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > iPhone ,iPod & iPad (Apple Inc. Products) > iPhone 7 / iPhone 7 Plus
Old 11-07-2017, 17:55   #1 (permalink)
Member: 1709244
Sonork: gsmnasir
Thanks Meter: 45
iPhone 7 hang on apple logo
I got an iPhone 7, it's sometime getting stuck and mic/earpiece not work. then I restored and restore complete. fine, but after restored not power on. just hang on apple logo.
Anybody plzzz
Old 11-08-2017, 14:57   #2 (permalink)
Moderator
tkowsar's Avatar
Member: 233205
Thanks Meter: 5,014
Anybody plzzz
There are few more similar issue which has different causes. So you have to try one by one, start with that
-http://forum.gsmhosting.com/vbb/f1002/iphone-7-stuck-screen-problem-repair-solution-2273891/
Sometimes problem with front camera sensor flex cable too.
And at last there is problem with new update (11.1) which is effected wide range of iDevice, you can try to downgrade (11.0.3) or else you would wait for next update.
Old 11-25-2017, 04:53   #3 (permalink)
Crazy Poster
Member: 2713523
Thanks Meter: 15
Maybe you can try these.
Try This First: Restart the iPhone
The Next Potential Fix: Recovery Mode
If That Doesn't Work: DFU Mode
Old 11-26-2017, 11:19   #4 (permalink)
Member: 2250798
Thanks Meter: 19
if can't recored using voiec memos its 100 %audio ic related problem so first u remove audio ic and check audio ic print c12 if missing just connected from nearest resistor r1103.if connection is ok just replace your audio ic
The Following 2 Users Say Thank You to Shaheed sabu For This Useful Post:
Old 12-29-2017, 11:49   #5 (permalink)
Crazy Poster
Member: 2713523
Thanks Meter: 15
If your this problem is not solved, you can read thos article: Software Solution for iPhone Stuck on Apple Logo
Old 01-03-2018, 13:36   #6 (permalink)
smartengghelp's Avatar
Member: 740993
Thanks Meter: 75
Anybody plzzz
Hi
This is very common with iphone 7 and 7 plus.
Main reason is front camera flex. There is soldering connection on flex for proximity sensor and front camera.
When we remove it from old lcd sometime this connection get problem and it make phone to stuck on apple logo.
Even if you test iphone 7 or 7 plus without front camera it stuck on logo < or take long time to boot up> in ios 11.
So just test your phone with good New camera it will work.
I hope this will fix your problem as we did this many times.
Regards
Phonebeats
The Following User Says Thank You to smartengghelp For This Useful Post:
Old 01-03-2018, 13:44   #7 (permalink)
freeman2001's Avatar
Member: 206476
Thanks Meter: 459
audio ic must be changed
br
Page generated in 0.15736 seconds with 9 queries
