Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > iPhone ,iPod & iPad (Apple Inc. Products) > iPhone, iPad, iPod Hardware Repair
iPhone, iPad, iPod Hardware Repair Hardware Repair discussions for iPhone, iPod , iPad & Apple Products, help, guides.
Old 09-06-2018, 23:11   #1 (permalink)
Member: 2763390
Thanks Meter: 6
Iphone 7 no service
Iphone 7 no service, but showing imei with *#06#
What is the problem ? Bb or bb pmu ?
Az én iPhone készülékemről küldve a Tapatalk segítségével
The Following User Says Thank You to kgabor For This Useful Post:
Old 09-14-2018, 14:33   #2 (permalink)
Member: 2777379
Thanks Meter: 34
Have you tried with a different SIM card, the issue is likely not your modem Baseband if the IMEI is showing on #06, make sure the golden metal connectors on the SIM tray are clean, it could be your BB PMU or the network amplificator IC
The Following User Says Thank You to 7Axis For This Useful Post:
Old 09-14-2018, 14:34   #3 (permalink)
Member: 2763390
Thanks Meter: 6
I tried 3 different sim card. Changed bb pmu, changed dock flex .... still no service :/
Old 10-13-2018, 10:05   #4 (permalink)
Gabidauri11's Avatar
Member: 2722292
Thanks Meter: 24
It does not matter. Because it will work *#06#
The Following User Says Thank You to Gabidauri11 For This Useful Post:
Old 10-13-2018, 10:10   #5 (permalink)
Member: 2314320
How to unlocking nokia china RDA coolsand throgh miracle box thank you.
Old 10-15-2018, 08:43   #6 (permalink)
Member: 1911098
Thanks Meter: 16
Wrong section for this question.
The Following User Says Thank You to simeon_tsvetkov For This Useful Post:
Old 10-18-2018, 08:10   #7 (permalink)
Member: 2861866
Thanks Meter: 71
restore to factory setting. If your phone is the one that is covered under the iphone 7 "no service" problem then restoring to factory settings will brick the phone (shows an unknown error) because it is a hardware issue, not a software one.
The Following User Says Thank You to Amanda0820 For This Useful Post:
Old 11-13-2018, 14:42   #8 (permalink)
Member: 1986680
Sonork: 7210
Thanks Meter: 21
go to setting then general then reset click reset network settings hope it works
Old 11-26-2018, 07:09   #9 (permalink)
Member: 1380639
Sonork: FS_354
Thanks Meter: 4
Check out C5820_RF and remove it then try to insert your sim card and reset network settings.
Old 01-04-2019, 08:37   #10 (permalink)
Member: 2886931
Thanks Meter: 8
this is blaind reparation, you need to have oscilloscope to find where is the signal dropped.
Page generated in 0.15139 seconds with 8 queries
