View Poll Results: What's the problem? | |||
NAND | 13 | 68.42% | |
Other; please elaborate | 6 | 31.58% | |
Voters: 19. You may not vote on this poll |
08-13-2019, 00:50 | #1 (permalink) |
Junior Member Join Date: Aug 2019 Location: florida
Member: 2922349 Status: Offline Thanks Meter: 0 | iPhone 7 Plus Error 4005, stuck in DFU I'm new to microsoldering, so I don't really know where to start. I've tried a different battery and charge port, as well as disconnecting secondary components like the screen. I've tried different computers and different cables. Is it probable it's the NAND? Should I go ahead and try to reball it? Here's the tail-end of the iTunes log. Code: [04:13:45.0664] WinDFU::ResetDevice: resetting... [04:14:00.0905] WinDFU::FinalizeDfuUpdate: success [04:14:00.0905] <DFU Device 0000000002634030>: DFU succeeded [04:14:00.0905] Finished DFU Restore Phase: Successful [04:14:00.0936] DFU mode device disconnected [04:14:00.0936] Device removed when in state Restoring, moving device to transition state [04:14:00.0936] Changing state from 'Restoring' to 'Transitioning' [04:14:00.0936] Creating timer to monitor transition [04:14:00.0936] Creating a timer for 10 minutes [04:24:00.0961] Restore completed, status:4005 [04:24:00.0961] Failure Description: [04:24:00.0961] Depth:0 Code:4005 Error:Gave up waiting for device to transition from DFU state to DFU state. |
09-03-2019, 13:51 | #2 (permalink) |
Freak Poster Join Date: May 2016 Location: Unlock world Age: 35
Member: 2578723 Status: Offline Thanks Meter: 15 | There are multiple reasons that causes iPhones get in DFU mode. You may want to use jc programmer to get rid of DFU, they just launched selling one. I personally didnt get a chance to try it but it worth it |
10-08-2019, 12:39 | #3 (permalink) |
Freak Poster Join Date: Apr 2014 Location: ******.amman Age: 39
Member: 2168728 Status: Offline Thanks Meter: 45 | same here with ip7+ 3utools says couldn't switch to recovery mode and some times its says the idevice could be disconnected its crazy... my friend said its ram issue but i dont believe that ... any one know about that issue ? |
08-21-2020, 10:42 | #6 (permalink) |
Freak Poster Join Date: Jun 2017 Location: USA
Member: 2730637 Status: Offline Thanks Meter: 101 | Error 21, 9, 2009, 4005, 14, 40 usually indicates NAND flash or CPU malfunction. You can check the video below. |
The Following User Says Thank You to phryne For This Useful Post: |
