01-09-2019, 10:04 | #16 (permalink) |
Junior Member Join Date: Jan 2019 Location: Denmark
Member: 2886931 Status: Offline Thanks Meter: 8 | i had go through this problem many times so i made vedio in my channel. Plesae visit and check all the vedio https://www.youtube.com/channel/UCCl..._as=subscriber |
The Following User Says Thank You to Tareqd60 For This Useful Post: |
01-31-2019, 10:10 | #20 (permalink) |
Insane Poster Join Date: Mar 2013 Location: nigeria
Member: 1903487 Status: Offline Sonork: 100.1654467 Thanks Meter: 8 | Has anybody try black sim(chip) to activate let see.solution is how to put missing udid.A beta version was used to restore the phone. Sent from my iPhone using Tapatalk Pro |
02-02-2019, 01:15 | #22 (permalink) |
Member: 1903487 Status: Offline Sonork: 100.1654467 Thanks Meter: 8 | It is an hardware issue, imeil is corrupt and baseband missing. Nand program should solve I will try soon. Sent from my iPhone using Tapatalk Pro |
04-18-2019, 11:54 | #24 (permalink) |
Junior Member Join Date: Jun 2017
Member: 2730111 Status: Offline Thanks Meter: 1 | you have to make sure latest iTune on iPhone connect it with your system wait for a while iTunes to detects and activates your iPhone: If iTunes shows, "Set up as New" or "Restore from Backup," it means that iTunes activated your iPhone. |
05-09-2019, 09:51 | #25 (permalink) |
Insane Poster Join Date: Aug 2006 Location: Spain Age: 44
Member: 328453 Status: Offline Thanks Meter: 1 | same problem : Unable to Activate an Update is Required to Activate your iPhone have 1x iphone 6s and iphone 7 without imei and i updated now 5 times NOT POSIBLE FOR ACTIVATE: PLEASE SOLUTION |
05-29-2019, 04:21 | #27 (permalink) |
Banned Join Date: May 2019 Location: surabaya
Member: 2910296 Status: Offline Thanks Meter: 1 | if you are a cellphone technician who often receives broken iPhones then you are not wrong to join our group F-FinderTool team https://chat.whatsapp.com/Ko1TOAnWEAw9EeLU7cdGLj |
The Following User Says Thank You to Prayugo For This Useful Post: |
08-14-2019, 12:37 | #30 (permalink) |
Insane Poster Join Date: Jan 2018
Member: 2797527 Status: Offline Thanks Meter: 4 | If your iPhone 7 is unable to activate, you can go to have a careful check for the network connection, SIM status or start over to try again, try with iTunes, restart device. Moreover, the most efficient and trusted way is to repair it with an iOS system recovery, such as Joyoshare UltFix, to get it back to normal with no data loss. In case there is a potential system issue, you can give it a try. |
