06-09-2019, 23:48 | #1 (permalink) |
Freak Poster Join Date: Oct 2012 Location: United Arab Emirates
Member: 1829029 Status: Offline Thanks Meter: 20 | iphone 7plus dead no power I did change audio ic with c12 jumber - but not work 3,4 time I changed ic, no luck. Before 100+ success. Now mobile complete dead and low amp Experts any suggestions please...? Very urgent |
The Following User Says Thank You to itzshafeek For This Useful Post: |
06-15-2019, 17:37 | #3 (permalink) |
No Life Poster Join Date: Feb 2009 Location: inside apples a15
Member: 975554 Status: Offline Sonork: KG state:prenormal Thanks Meter: 253 | if no other problems only one time replacing audio ic will do the job but if you already change it 3 to 4 times then its not in audio ic anymore..try to trace every line in audio ic maybe you have short pins there...check also capacitors near that ic maybe some of them moved when you try to work on the ic and short them..remove all the shield in ic so that you will see all parts what is missing |
