09-20-2016, 10:25 | #1 (permalink) |
Freak Poster Join Date: Jan 2009 Location: bangladesh,ctg,sandwip Age: 33
Member: 950002 Status: Offline Sonork: Laa Elaha Ellallah Thanks Meter: 119 | iphone7 & 7plus how to make recovery mode hi,everybody yesterday i got n iphone7 disable password, then try to make recovery mode for restore software but not come recovery mode as old trick(home+power) then i search on google also i don't get.. thinking thinking and finaly i got the recovery mode trick..new trick is(power+volume+ & volume-) see the pic below: press and hold (power key+volume up+volume down) or power off the mobile then press & hold both of volume key then put charging cable. hold that key until see the recovery mode. |
The Following 7 Users Say Thank You to farhadcomputer For This Useful Post: |
09-30-2016, 13:21 | #2 (permalink) |
Freak Poster Join Date: Feb 2014 Location: Greece
Member: 2130293 Status: Offline Sonork: 100.1637594 Thanks Meter: 68 | tep 1: Make sure that you have the latest version of iTunes installed. Step 2: Plug in your iPhone 7 or iPhone 7 Plus to your computer via a lightning USB cable. Step 3: Next, turn off your iPhone. Step 4: Now press and hold down the Lock button on the right side of your iPhone for 3 seconds. Step 5: At the same time, press and hold the volume down button on the left side of your iPhone while still holding the Lock button. Keep holding both the buttons for 10 seconds. Step 6: If you see the Apple logo on your screen, then you have to start all over again as you held the buttons for too long. Otherwise, continue with the steps below. Step 7: Then release the Lock button but keep holding down the volume down button for another 5 seconds. If you see the “Plug into iTunes” screen, then you have held it for too long and have to start all over again. Step 8: If the screen remains black, then it means you have entered DFU mode successfully! Congrats! iTunes should now display a message that it has detected your iPhone 7 or iPhone 7 Plus and will allow it to be restored. tested |
02-15-2017, 09:03 | #8 (permalink) |
Moderator Join Date: Jan 2011 Location: Throne of GsmHosting
Member: 1483853 Status: Offline Sonork: 100.1611111 Thanks Meter: 1,628 | its only volu down key. inshort every things is same you just have to use volum down as home key to put your phone in recovery or DFU mode. |
02-15-2017, 09:03 | #9 (permalink) |
