Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > iPhone ,iPod & iPad (Apple Inc. Products) > iPhone 7 / iPhone 7 Plus
Old 09-30-2018, 07:56   #1 (permalink)
Member: 2861866
Thanks Meter: 71
[Solution]A New Way to Repair iPhone 7/7Plus Home Button
The iPhone 7 home button will only work with the original home button that it was shipped with; if it breaks and needs to be replaced, it means that replaced home button would be a non-functional home button. No Touch ID and no return-to-home functionality.
use customized charging port flex cable to restore the return-to-home function of your home button.
Old 10-02-2018, 09:13   #2 (permalink)
Member: 270730
Thanks Meter: 67
https://rewatechnology.com/apple-iph...ent-15564.html
Old 10-17-2018, 18:58   #3 (permalink)
Member: 236667
Thanks Meter: 12
But the item is not available.Also I'm interested on the way that solution is working.It is a otg keyboard emulated?
Old 10-19-2018, 11:33   #4 (permalink)
Member: 2833946
Thanks Meter: 108
After upgrading the parts for iPhone 7 broken home button - Customized charging flex cable, the functions as following
  • Restore return-to-home function
  • Support PD fast charging
  • Support different type of charger adapters from 0.5A-2.4A
  • Be able to take screenshots on all iOS versions
  • More comfortable touch feeling
Details and more info you can read Upgraded Parts for iPhone 7 Broken Home Button Repair
The Following 2 Users Say Thank You to AmieeWhite For This Useful Post:
Old 10-20-2018, 02:07   #5 (permalink)
Member: 2784527
Thanks Meter: 9
oh, is it really? that should be a try 'cause I have an iPhone 7P which damaged home button in May, and I have no Touch and back function. How can I contact you?
Old 10-20-2018, 03:28   #6 (permalink)
Member: 2833946
Thanks Meter: 108
You should contact REWA(www.rewatechnology.com), they can offer the parts for iPhone 7 home button with customized charging flex cable, they also can help you to fix your iPhone 7 plus if you need
The Following User Says Thank You to AmieeWhite For This Useful Post:
Page generated in 0.15064 seconds with 8 queries
