08-01-2018, 08:18 | #1 (permalink) |
Banned Join Date: Jul 2018 Age: 35
Member: 2851558 Status: Offline Sonork: 83207ae144c0950d30889f72b Thanks Meter: 3 | What should I do if the iPhone 7 Plus screen is Broken? 1. The outer layer is tempered. 2. It has a 3D TOUCH gravity sensitive liquid crystal layer. 3. Capacitive pressure sensing layer. Apple’s official website and partner store’s approach: 1:Pay the fee to*Replacement 2:If the conditions for the new machine are met, the fuselage and the main board are not bent, deformed, worn, and there is no trace of water.Can make up the difference, in exchange for a new iPhone 7 Plus. There are two ways to replace a normal professional repair shop: 1: *the screen display is normal, no discoloration, normal touch, this description is only bad external screen, you can change the external screen. 2: *If the screen is abnormal, there are vertical stripes, black blocks, apertures, and touches that are comprehensive or partially malfunctioning. Need to replace the entire iPhone 7 Plus screen. Let me talk about the process of changing the external screen in detail: 1:*Separating the screen and cutting out the bad external screen in the clean room and dust removal equipment 2:*With optical glue glue, focus gland and other processes, defoamer defoaming, re-pressing the outer screen to the inner screen. If the internal screen is broken, it can only change the whole screen. If you change the whole screen, you don't pay attention to any technology. Basically, it is necessary to disassemble a few screws. It is good to start the cable and the fingerprint cable. Do not tear it off. The most important thing is to guarantee the change. The original screen, otherwise it will easily lead to machine jumping, black screen, flower screen and touch failure. iPhone 7 Plus disassemble repair video Last edited by loca|host; 08-03-2018 at 10:56. Reason: advertise removed |
08-14-2018, 11:18 | #2 (permalink) |
Freak Poster Join Date: May 2018
Member: 2833946 Status: Offline Thanks Meter: 108 | If you are a repair engineer, you know that using the LCD refurbishing machine can maximize the profits and minimize the damage. I have found two broken screen refurb guide, one is a special case for the lcd refurbishing, another is the tips and tricks for the lcd refurbishing. It is worth to take a look. Special case: iPhone 7 Plus Broken Screen Refurbishing Tips and Tricks for the LCD refurbishing |
08-14-2018, 15:56 | #3 (permalink) |
Insane Poster Join Date: Jan 2016 Location: GSX Checks source
Member: 2511554 Status: Offline Sonork: 100.1671270 Thanks Meter: 11 | Its kind a cheap to fix outer layer of screen. Try to find any shops nearby and ask them to refurbish same original screen. It my local country for iph 7+ costs arround 80-90usd. |
