How to Cope Without Invalid Setting IMEI Code Error * What is IMEI? IMEI is short for International Mobile Equipment Identity. IMEI is a unique code that each device has. Usually 15 or more digits. Each device has an IMEI number is not the same. To see your device's IMEI number, you can type * # 06 # key. Or you can see on the back of the device or usually attached to the sticker on the box of the device. IMEI numbers can not be changed altogether. Because it is the default of the factory / vendor that makes it. Therefore, IMEI itself has a special meaning that signifies the manufacturer, type hp and others. * Get to know IMEI Many countries have recognized the use of IMEI in reducing the effects of cell phone theft. IMEI (14 decimal digits plus check digit) or IMEISV (16 digits) includes information about the device's origins, model, and serial number. The IMEI / SV structure is set in 3GPP TS 23.003. The model and origin consist of the initial 8 digits IMEI / SV, known as the Type Allocation Code (TAC). The rest of the IMEI is the manufacturer set, with Luhn check digits at the end. For the IMEI format prior to 2003, the GSMA guideline is to have this Check Digit always transmitted to the network as zero. These guidelines appear to have disappeared for valid formats from 2003 onwards. How to Overcome Not Invalid Setting IMEI / MMI code Solution Connection Error: IMEI Lost in Android IOS RIM, KTouch, Hitech, MYG, IMO, eTouch, Taxco, Beyond, Startech, Asiaphone, Mito, Mixcon, Tocall, S-Nexian, Cross Polytron, Toshiba Mito, IMO, Cross, Nexian, Tiphone Sony, Panasonic, Toshiba, Sharp, Kyocera, DoCoMo, Casio K-Touch, Huawei, Haier, G-Tide, Lenovo, Oppo, ZTE Acer, Asus, HTC, Ben Q, Samsung , LG, Apple, iPhone, Motorola, RIM, Blackberry, Nokia Siemens, Alcatel, Sagem, Philips, Vertu Ti, Ninetology, CSL Blueberry, Micxon, OliveSmart, Idea MMI code Invalid in Android could have happened Android brand anything, can Only Lenovo, Samsung Galaxy, or other Android vendors. Connection Problems and Invalid MMI Code on Android occur while checking the pulse and activation of Internet packages with the provider.... When accessing the check pulse or buy a packet of data it would appear Problems Samsbungan and MMI code not valid or in English "Connection problem or Invalid Code IMEI / MMI", but do not panic, all problems can be solved can in a short time and can also take in a few days. For that there are How to Solve Connection Problems and Invalid IMEI / MMI Code on Android, Invalid IMEI / MMI Code Problem or Imei Missing on Android occurs on various types of smartphone mobile phones. Not invalid IMEI / MMI damage solution Read Also: HP Service Course. Initial Solution Setting IN Mobile Phone Android Smartphone Android Mobile Software Damage: 1. type the following code in Dialer HH * # * # 3646633 # * # * it will go to "EngineerMode" 2. Next select the "Connectivity" bar and on the bar select "CDS Information" 3. Then select again "Radio Information" and will appear 2 button "Phone 1" and "Phone 2" Select "Phone 1" 4. Enter the IMEI No. by writing AT + EGMR = 1.7, "input no imei here" then click "SEND AT COMMAND" then it will appear a description describing the success of input. 5. * For "Phone 2" input no second IMEI by writing AT + EGMR = 1.10, "input no imei to 2 here" then click "SEND AT COMMAND". 6. When finished input, Reboot or Restart HH and check IMEI by type * # 06 # on Dialer, and IMEI has reappeared. 7. Completed Process Sometimes there is HH dual sim which only has 1 IMEI, then input no imei same on phone 1 and phone 2.... |
