Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > DC Unlocker
Old 01-14-2020, 07:08   #1 (permalink)
jailbreak-how's Avatar
Member: 1598016
Thanks Meter: 54
ANE-LX2 Huawei P20 lite unbrick failed
device didn't turn on
huawei usb 1.0 only in device manager
i tried it with ANE-Full-Repair-NV-included-Board-A039-8.0.0.dgtks
but give errors see below
DC Phoenix 0.0.0.118
user:xxxxxx
Looking for a device in force upgrade mode
No devices detected in force upgrade mode
Looking for a device in fastboot mode
Device found: WCY4C18629001030
1/14/2020 10:58:10 AM Starting to write device in FASTBOOT mode...
File to update: C:\Users\fahad\Downloads\ANE-Full-Repair-NV-included-Board-A039-8.0.0.dgtks
Getting IMEI...
Getting build number...
Getting model ...
Getting model by product ...
Getting model by roduct ...
Getting battery state...
Getting backdoor info...
Getting lock state info...
Getting lock boot info...
Model: hi6250
Battery state: 0
OEM lock state info:
FB LockState: UNLOCKED
USER LockState: LOCKED
OEM get bootinfo:
unlocked
Process identifier:22145570
Waiting for OEM erase_storage_all command ...FAIL
Waiting for device REMOVAL/INSERTION...
USB Device REMOVAL
Type: @oem41.inf,%hwfastboot%;Android Sooner Single ADB Interface
VidPid: VID_18D1&PID_D00D
Instance id: 5&345390ff&0&3
USB Device INSERTION
Type: @oem77.inf,%qcomdevice00%;HUAWEI USB COM 1.0
VidPid: VID_12D1&PID_3609
Instance id: 5&2523fa13&0&1
Device detected:
COM1345: HUAWEI USB COM 1.0 (COM1345)
Writing bootloader...
Step 1...
Step 2...
Waiting for fastboot device...
Getting IMEI...
Getting model ...
USB Device REMOVAL
SN:WCY4C18629001030
IMEI:867907037441654
IMEI1:867907037456660
MEID:A0000091D2921D
Build number: :ANE-LX2 9.1.0.237(ZAFC185E4R1P8)
Model: ANE-LX2
Vendor/Country: Vendor/Country: hw/meafnaf
Battery state: 0
OEM get bootinfo:
unlocked
Writing xloader partition
Waiting for answer...
XLOADER partition update :FAIL flash write prim vrl failure
Cannot get FBlock info from device
Trying to unlock device...
Signing process may take few minutes
Trying to get data from server
Unlock process finished successfully
Writing ptable partition
PTABLE partition update ...OK
Writing fastboot partition
FASTBOOT partition update :FAIL flash write prim vrl failure
Writing dts partition
DTS partition update :FAIL flash write prim vrl failure
Writing fw_lpm3 partition
FW_LPM3 partition update :FAIL flash write prim vrl failure
Writing sensorhub partition
SENSORHUB partition update :FAIL flash write prim vrl failure
Writing fw_hifi partition
FW_HIFI partition update :FAIL flash write prim vrl failure
Writing teeos partition
TEEOS partition update :FAIL flash write prim vrl failure
Writing recovery_vbmeta partition
RECOVERY_VBMETA partition update :FAIL flash write prim vrl failure
Erasing cache partition
ERASE partition cache : FAIL failed to erase partition
Writing cache partition
CACHE partition update :FAIL failed to erase partition when sparse img flash
Writing nvme partition
NVME partition update :FAIL flash write failure
Writing trustfirmware partition
TRUSTFIRMWARE partition update :FAIL flash write prim vrl failure
Writing modem_fw partition
MODEM_FW partition update :FAIL flash write prim vrl failure
Writing modemnvm_update partition
MODEMNVM_UPDATE partition update :FAIL flash write failure
Writing modem_om partition
MODEM_OM partition update :FAIL failed to erase partition when sparse img flash
Writing modemnvm_img partition
MODEMNVM_IMG partition update :FAIL failed to erase partition when sparse img flash
Writing modemnvm_backup partition
MODEMNVM_BACKUP partition update :FAIL flash write failure
Writing modemnvm_factory partition
MODEMNVM_FACTORY partition update :FAIL flash write failure
Writing modemnvm_system partition
MODEMNVM_SYSTEM partition update :FAIL flash write failure
Erasing userdata partition
ERASE partition userdata : FAIL failed to erase partition
Writing userdata partition
USERDATA partition update :FAIL failed to erase partition when sparse img flash
Writing system partition
sending sparse file 413714128 bytes
send sparse file ERROR
SYSTEM partition update FAIL
Fatal error: Cannot access to device
1/14/2020 11:06:02 AM Writing device finished - INCOMPLETE
I also tried bootloader with oem info but it cant flash
Old 01-14-2020, 10:11   #2 (permalink)
solgeo's Avatar
Member: 2778414
Thanks Meter: 80
Hello
Download and flash this file
ANE-Downgrade-Board-A039-8.0.0.dgtks
And yes, board firmware is flashed through the point (testpoint)
and you are flashing through fastboot
Old 01-15-2020, 09:33   #3 (permalink)
Member: 1598016
Thanks Meter: 54
Originally Posted by solgeo View Post
Hello
Device detected:
COM1353: HUAWEI USB COM 1.0 (COM1353)
1/15/2020 1:25:16 PM Starting to write device in FASTBOOT mode...
File to update: C:\Users\fahad\Desktop\ANE-Downgrade-Board-A039-8.0.0.dgtks
Device detected:
Process identifier:22178027
Step 1...
Step 2...
Getting IMEI...
Getting model ...
SN:WCY4C18629001030
MEID:A0000091D2921D
Model: ANE-LX2
Battery state: 0
OEM get bootinfo:
unlocked
USB Device REMOVAL
Instance id: 5&3a31f43d&0&2
Instance id: 5&345390ff&0&6
Erasing ver .. .
Cannot get HW FBlock info from device
Writing huawei_crc_check partition
HUAWEI_CRC_CHECK partition update ...OK
XLOADER partition update ...OK
FASTBOOT partition update ...OK
Writing kernel partition
KERNEL partition update ...OK
Writing ramdisk partition
RAMDISK partition update ...OK
Writing vbmeta partition
VBMETA partition update ...OK
Writing odm partition
ODM partition update ...OK
Writing recovery_ramdisk partition
RECOVERY_RAMDISK partition update ...OK
Writing recovery_vendor partition
RECOVERY_VENDOR partition update ...OK
RECOVERY_VBMETA partition update ...OK
Erasing cust partition
ERASE partition cust : FAIL flash write prim vrl failure
Erasing misc partition
ERASE partition misc : FAIL failed to erase partition
Partition cache erased
CACHE partition update ...OK
FW_LPM3 partition update ...OK
FW_HIFI partition update ...OK
TEEOS partition update ...OK
TRUSTFIRMWARE partition update ...OK
SENSORHUB partition update ...OK
DTS partition update ...OK
MODEMNVM_UPDATE partition update ...OK
MODEM_FW partition update ...OK
send sparse file OK
sending sparse file 471379936 bytes
send sparse file OK
sending sparse file 463200008 bytes
send sparse file OK
sending sparse file 77705316 bytes
send sparse file OK
SYSTEM partition update ...OK
phone still in huawei usb 1.0 mode
and during flashing display was black in fastboot mode
Old 01-15-2020, 16:38   #4 (permalink)
Member: 2023196
Thanks Meter: 1,249
it doesn't seem that you read anything mate. Did you put a check mark on "slow algo/old" option on DC-phoenix, its a must for your phone's processor.
Page generated in 0.28732 seconds with 7 queries
