Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > DC Unlocker
Old 04-01-2020, 17:59   #16 (permalink)
Shensohau's Avatar
Member: 1377783
Sonork: 100.1611724
Thanks Meter: 2,848
Hi, I have ALE-L23 device I need try to reflash it but not allowed by other tools, maybe dc will can do it?? Im unknow original firmware, I have this flash for it ALE-L23_C605B140_Firmware_Northern_Latin_America_Regio n_Channel-Others_Android_5.0_EMUI_3.1_05012YHP
Old 04-01-2020, 18:01   #17 (permalink)
Member: 2108610
Thanks Meter: 343
Please make videotutorial for bypass version and downgrade
The Following User Says Thank You to yosbel182us For This Useful Post:
Old 04-01-2020, 18:08   #18 (permalink)
..::GMSR::..'s Avatar
Member: 1444462
Thanks Meter: 605
STK-L01M 10.0.0.185(C316E4R4P1 Cannot Downgrade
Model: STK-L21
Firmware ver.: STK-L01M 10.0.0.185(C316E4R4P1
Hi, DC Team its possible to downgrade ?
Loo
Looking for a device in upgrade mode
No devices detected in upgrade mode
Device found: RSV4C19923002920
Detecting recovery partition
File size: 3,808,184,572 bytes
Current version(BASE_VER): STK-LGRP3-OVS 9.0.1.170
ERECOVERY_KERNEL partition found
ERECOVERY_RAMDISK partition found
ERECOVERY_VENDOR partition found
4/1/2020 7:11:05 PM Starting to try Rescue Recovery...
Looking for a device in fastboot mode
Getting IMEI...
Getting build number...
Getting model ...
Getting battery state...
Getting backdoor info...
Getting lock state info...
Getting lock boot info...
Build number: :STK-L01M 10.0.0.185(C316E4R4P1)
Model: STK-L21
Vendor/Country: vodacom/za
Battery state: 4233mv
OEM lock state info:
FB LockState: LOCKED
USER LockState: LOCKED
OEM get bootinfo:
locked
Getting base version...
Base Version: STK-LGRP3-OVS 10.0.0.185
Getting cust version...
Cust Version: STK-L01M-CUST 10.0.0.4(C316)
Getting preload version...
Preload Version: STK-L01-PRELOAD 10.0.0.1(C316R4)
Process identifier:23719985
Erasing ver .. .
Writing rescue_recovery_kernel partition
RESCUE_RECOVERY_KERNEL partition update ...OK
Writing rescue_recovery_ramdisk partition
RESCUE_RECOVERY_RAMDISK partition update ...OK
Writing rescue_recovery_vendor partition
RESCUE_RECOVERY_VENDOR partition update ...OK
Uptade recovery parttion OK
USB Device REMOVAL
Type: @oem24.inf,%singlebootloaderinterface%;Android Bootloader Interface
VidPid: VID_18D1&PID_D00D
Instance id: RSV4C19923002920
Looking for device in upgrade mode...
USB Device INSERTION
Type: @oem20.inf,%busfilter.devicedesc%;USB Composite Device
VidPid: VID_12D1&PID_107E
COM7: Android Adapter PCUI (COM7)
COM6: DBAdapter Reserved Interface (COM6)
Enter recovery mode OK
4/1/2020 7:11:40 PM Starting to write device in UPGRADE mode...
Old slow algo NOT selected
4/1/2020 7:11:42 PM start to write update file
File to update: D:\Huawei FRP Solution\STK-L21 Y9 Prime\STK-L21M 10.0.0(C185) Downgrade For FRP Bypass\A_Update.APP
Process identifier:23720003
Validating file...
Looking for attached port...
Preparing to write...
Error downloading file 1 of 44
Error writing software
4/1/2020 7:11:51 PM Writing device finished with ERROR
Old 04-01-2020, 18:48   #19 (permalink)
Member: 1444462
Thanks Meter: 605
I have try also another firmware, but still same error.
DC Phoenix 0.0.0.125
user:
File size: 3,808,201,076 bytes
4/1/2020 7:34:39 PM Starting to try Rescue Recovery...
Getting IMEI...
Getting model ...
Model: STK-L21
Battery state: 4256mv
OEM get bootinfo:
locked
Process identifier:23720284
Erasing ver .. .
USB Device REMOVAL
4/1/2020 7:35:19 PM Starting to write device in UPGRADE mode...
4/1/2020 7:35:21 PM start to write update file
File to update: D:\Huawei FRP Solution\STK-L21 Y9 Prime\5._STK-L21_9.1.0.277(C185E2R4P1).APP
Process identifier:23720289
Validating file...
Writing file 1 of 44: SHA256RSA...OK
Writing file 2 of 44: CRC...OK
Writing file 3 of 44: BASE_VERLIST...
Error downloading file 3 of 44
4/1/2020 7:35:39 PM Writing device finished with ERROR
another version firmware also same error.
File size: 3,892,426,284 bytes
4/1/2020 7:52:11 PM Starting to try Rescue Recovery...
Getting IMEI...
Getting model ...
Model: STK-L21
Battery state: 4269mv
OEM get bootinfo:
locked
Process identifier:23720423
Erasing ver .. .
USB Device REMOVAL
4/1/2020 7:52:55 PM Starting to write device in UPGRADE mode...
4/1/2020 7:52:58 PM start to write update file
File to update: D:\Huawei FRP Solution\STK-L21 Y9 Prime\1_312_.APP
Process identifier:23720430
Validating file...
4/1/2020 7:53:14 PM Writing device finished with ERROR
Old 04-01-2020, 19:13   #20 (permalink)
Member: 15156
Thanks Meter: 42
you using wrong variant firmware check your pm let me know
Old 04-01-2020, 20:49   #21 (permalink)
Member: 2594096
Thanks Meter: 16
COM10: Android Adapter PCUI (COM10)
COM11: DBAdapter Reserved Interface (COM11)
02/04/2020 12:47:38 am Starting to write device in UPGRADE mode...
Device found: EDN0219B16014237
02/04/2020 12:47:40 am start to write update file
File to update: D:\10.0.0.182\Flash\6_base_UPDATE.APP
File size: 5,191,703,932 bytes
Current version(BASE_VER): LION-LGRP3-CHN 10.0.0.180
Process identifier:23721588
Validating file...
Bypass version checked
Checking partition ...
Writing file 1 of 55: SHA256RSA...OK
Writing file 2 of 55: CRC...OK
Writing file 3 of 55: BASE_VERLIST...
Error downloading file 3 of 55
02/04/2020 12:48:02 am Writing device finished with ERROR
I tried on LIO-AN00P 10.0.0.195
I tried 10.0.0.182 Firmware and LIO-N29 Same version firmware but not working can be guide me what shall I do.
Old 04-01-2020, 21:19   #22 (permalink)
Member: 809650
Thanks Meter: 19
Dc phoenix 1st huawei Phone solution And Always Give Us Unique And 1st Solutions.Other Teamm W8ng always for Dc Update And Then Copy immedeitly 🤣🤣
Old 04-01-2020, 21:19   #23 (permalink)
:Aishur:'s Avatar
Member: 1315677
Thanks Meter: 1,224
@ Talha34214012
Kirin990 is still so fresh
It is not yet supported everywhere
The Following User Says Thank You to :Aishur: For This Useful Post:
Old 04-01-2020, 22:12   #24 (permalink)
selective member DC - Unlocker
Member: 3431
Thanks Meter: 12,163
Validating file...
Server not have all versions, You should select "Update verlist to server on file load" then select this version LIO-AN00P 10.0.0.195 (or other COMPATIBLE version) firmware files. After this step You should select "bypass version check" and downgrade to your preferred version. Data from LIO-AN00P 10.0.0.195 version will be used for bypass next flashing.
Idea is next :
1 user load version to server, example You will load LIO-AN00P 10.0.0.195 .
all other users can program LIO-AN00P 10.0.0.195 version too without having this firmware. But for first user is necessary.
The Following 2 Users Say Thank You to Arve For This Useful Post:
Old 04-01-2020, 22:15   #25 (permalink)
Member: 3431
Also be careful, this method may allow write other or not compatible firmware. Phone can be bricked without repair solution.
Old 04-01-2020, 22:20   #26 (permalink)
Member: 1444462
Thanks Meter: 605
STK-L21, i have already done [+/-] 10 pecs of the phone, the version had inside android 9.1.XX , now the days only the android 10 version not working.
Old 04-01-2020, 22:31   #27 (permalink)
Yasir Ali's Avatar
Member: 270869
Sonork: 100.1600061
Thanks Meter: 346
lease make a totur for new features
Or vedio and need to upload c185 firmware for frp all models please
The Following User Says Thank You to Yasir Ali For This Useful Post:
Old 04-02-2020, 00:40   #28 (permalink)
Member: 1444462
Thanks Meter: 605
thanks for file but no luck.
user:
File size: 3,763,867,744 bytes
4/1/2020 11:47:38 PM Starting to try Rescue Recovery...
Getting IMEI...
Getting model ...
Model: STK-L21
Battery state: 4347mv
OEM get bootinfo:
locked
Process identifier:23722502
Erasing ver .. .
USB Device REMOVAL
4/1/2020 11:48:17 PM Starting to write device in UPGRADE mode...
4/1/2020 11:48:19 PM start to write update file
File to update: C:\Users\hp\Downloads\STK-L01M (C316) Downgrade From 10.0.0 To 9.1.0 and Fix Hang On eRecovery\STEP2\STEP2-Update.APP
Process identifier:23722507
Validating file...
Writing file 1 of 41: SHA256RSA...OK
Writing file 2 of 41: CRC...OK
Writing file 3 of 41: BASE_VERLIST...
Error downloading file 3 of 41
4/1/2020 11:48:37 PM Writing device finished with ERROR
Old 04-02-2020, 01:28   #29 (permalink)
rebainoor's Avatar
Member: 231728
Thanks Meter: 1,450
user:
Getting IMEI...
Getting model ...
Model: STK-L21
OEM get bootinfo:
locked
Erasing ver .. .
USB Device REMOVAL
Validating file...
Firstely you need download this version STK-L01M 10.0.0.185(C316E4R4P1) the same installed in your mobile to uploade VERLIST to server After that you Can downgrade it
The Following User Says Thank You to rebainoor For This Useful Post:
Old 04-02-2020, 16:22   #30 (permalink)
Member: 1444462
Thanks Meter: 605
unfortunately i don't have the STK-L01M 10.0.0.185(C316E4R4P1) firmware can you organised for me.
thanks
Page generated in 0.15525 seconds with 7 queries
