Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > DC Unlocker
Old 04-02-2020, 17:10   #31 (permalink)
rebainoor's Avatar
Member: 231728
Thanks Meter: 2,103
I dont have but you Can try with online package firmware
Old 04-02-2020, 17:48   #32 (permalink)
Member: 2594096
Thanks Meter: 17
Originally Posted by Arve View Post
Server not have all versions, You should select "Update verlist to server on file load" then select this version LIO-AN00P 10.0.0.195 (or other COMPATIBLE version) firmware files. After this step You should select "bypass version check" and downgrade to your preferred version. Data from LIO-AN00P 10.0.0.195 version will be used for bypass next flashing.
Idea is next :
1 user load version to server, example You will load LIO-AN00P 10.0.0.195 .
all other users can program LIO-AN00P 10.0.0.195 version too without having this firmware. But for first user is necessary.
Looking for a device in upgrade mode
COM10: Android Adapter PCUI (COM10)
COM11: DBAdapter Reserved Interface (COM11)
02/04/2020 9:45:42 pm Starting to write device in UPGRADE mode...
Device found: EDN0219B16014237
Old slow algo NOT selected
02/04/2020 9:45:45 pm start to write update file
File to update: D:\Taurus-AN00B 10.0.0.195(C00E190R7P2)_Firmware_EMUI10.0.0_05016B MA_2\dload\LIO-AN00P-10.0.0.195 BASE.APP
File size: 5,163,909,008 bytes
Current version(BASE_VER): TAS-LGRP3-CHN 10.0.0.190
Process identifier:23734652
Validating file...
Looking for attached port...
Preparing to write...
Bypass version checked
Checking partition ...
Writing file 1 of 54: SHA256RSA...OK
Writing file 2 of 54: CRC...OK
Writing file 3 of 54: BASE_VERLIST...
Error downloading file 3 of 54
Error writing software
02/04/2020 9:45:59 pm Writing device finished with ERROR
First I select LIO-AN00P 10.0.0.195 file and tick Upload to Server then I rename TAS-AN00B FILE to same as lio and untick server option and tick Bypass Option and Flash It but It is not working.
Can you please guide me where I am doing wrong.
Old 04-02-2020, 19:11   #33 (permalink)
selective member DC - Unlocker
Member: 3431
Thanks Meter: 12,477
Validating file...
What firmware in Your phone ? file name not effect this process at all.
Old 04-02-2020, 20:53   #34 (permalink)
Member: 2594096
Thanks Meter: 17
Originally Posted by arve View Post
what firmware in your phone ? File name not effect this process at all.
lio-an00p 10.0.0.195 c786
Old 04-02-2020, 21:34   #35 (permalink)
rebainoor's Avatar
Member: 231728
Thanks Meter: 2,103
But you select wrong firmware "Taurus-AN00B 10.0.0.195(C00E190R7P2)" its for TAS serie Line
And you have LIO-AN00P
The Following User Says Thank You to rebainoor For This Useful Post:
Old 04-02-2020, 22:50   #36 (permalink)
Member: 2594096
Thanks Meter: 17
My Phone is Huawei ID locked.
I can Flash LIO-AN00P 10.0.0.195 Firmware
But I need to remove Huawei ID
If I flash TAS firmware it will unlock Huawei ID
Both have 990 5G
Old 04-02-2020, 22:53   #37 (permalink)
Member: 3431
Both have 990 5G
If you think is safe ...
then try flash in fastboot with rescue, bypass selected.
Old 04-02-2020, 23:27   #38 (permalink)
Member: 2594096
Thanks Meter: 17
It gives me error at Rescue Recovery Partition even its own firmware.
I mean the emergency rescue recovery partition.
Cannot get length error.
Old 04-03-2020, 08:38   #39 (permalink)
Member: 2023196
Thanks Meter: 1,891
Send screenshot via pm or come to support chat, it doesn't seem you are doing steps correctly.
Old 04-20-2020, 00:17   #40 (permalink)
Member: 2865225
hcu client
bought a 72 "unlimited access" only to get 19 credits
Old 04-20-2020, 09:59   #41 (permalink)
Member: 2023196
Thanks Meter: 1,891
Well then maybe you have selected new user with credits instead of timed license account from item list?
Old 04-28-2020, 07:51   #42 (permalink)
Member: 1813429
Thanks Meter: 11
unbrick P30 Lite
hi sir help me to unbrick p30 lite. it stuck in recovery mode and what ever i flashed it give me error. please need your help
Old 04-28-2020, 08:04   #43 (permalink)
Member: 3431
Can you share one full log with error?
Old 04-28-2020, 11:12   #44 (permalink)
Member: 1813429
Thanks Meter: 11
finaly solved with this new version of dc phoenix. i cheicked rescue recovery and bypass version cheick box and flash goes without error here is full logs:
Standard update
Not Reboot NOT cheked
Update Verlist to server on file load NOT checked
Try Rescue Recovery checked
Bypass version check checked
Old slow algo NOT checked
No devices detected in upgrade mode
Device found: L2NDU19509041291
Detecting recovery partition
File size: 4*435*133*648 bytes
Current version(BASE_VER): Marie-LGRP2-OVS 9.1.0.270
ERECOVERY_KERNEL partition found
ERECOVERY_RAMDISK partition found
ERECOVERY_VENDOR partition found
2020-04-28 09:56:54 Starting to try Rescue Recovery...
Looking for a device in fastboot mode
Getting IMEI...
Getting build number...
Getting model ...
Getting battery state...
Getting backdoor info...
Getting lock state info...
Getting lock boot info...
Build number: :MAR-L21A 9.1.0.317(C432E5)
Model: MAR-LX1A
Vendor/Country: hw/eea
Battery state: 4381mv
OEM lock state info:
FB LockState: LOCKED
USER LockState: LOCKED
OEM get bootinfo:
locked
Getting base version...
Base Version: MAR-LGRP2-OVS 10.0.0.167
Getting cust version...
Cust Version: MAR-L21A-CUST 10.0.0.8(C432)
Getting preload version...
Preload Version: MAR-L21A-PRELOAD 9.0.1.3(C431R2)
Process identifier:24137236
Erasing ver .. .
Writing rescue_recovery_kernel partition
RESCUE_RECOVERY_KERNEL partition update ...OK
Writing rescue_recovery_ramdisk partition
RESCUE_RECOVERY_RAMDISK partition update ...OK
Writing rescue_recovery_vendor partition
RESCUE_RECOVERY_VENDOR partition update ...OK
Uptade recovery parttion OK
USB Device REMOVAL
Type: @oem103.inf,%singlebootloaderinterface%;Android Bootloader Interface
VidPid: VID_18D1&PID_D00D
Instance id: L2NDU19509041291
Looking for device in upgrade mode...
USB Device INSERTION
Type: @oem118.inf,%busfilter.devicedesc%;USB Composite Device
VidPid: VID_12D1&PID_107E
USB Device REMOVAL
Type: @oem68.inf,%vfsusbdevicename0011%;Synaptics FP Sensors (WBF) (PID=0011)
VidPid: VID_138A&PID_0011
Instance id: 17eef56fdd91
COM5: Android Adapter PCUI (COM5)
COM6: DBAdapter Reserved Interface (COM6)
Enter recovery mode OK
2020-04-28 09:57:26 Starting to write device in UPGRADE mode...
2020-04-28 09:57:30 start to write update file
File to update: C:\Users\Abdoulgaf\Desktop\MAR-L21\update_sd_base\UPDATE.APP
Process identifier:24137255
Validating file...
Writing file 1 of 46: SHA256RSA...OK
Writing file 2 of 46: CRC...OK
Writing file 3 of 46: BASE_VERLIST...OK
Writing file 4 of 46: BASE_VER...OK
Writing file 5 of 46: PACKAGE_TYPE...OK
Writing file 6 of 46: HISIUFS_GPT...OK
Software written
2020-04-28 09:57:42 start to update cust file
File to update: C:\Users\Abdoulgaf\Desktop\MAR-L21\update_sd_cust_MAR-L21A_hw_eea\UPDATE.APP
File size: 554*620 bytes
Current version(CUST_VER): MAR_Global-CUST 9.0.1(C999)
Process identifier:24137260
Validating file...
Writing file 1 of 7: SHA256RSA...OK
Writing file 2 of 7: CRC...OK
Writing file 3 of 7: CUST_VERLIST...OK
Writing file 4 of 7: CUST_VER...OK
Writing file 5 of 7: PACKAGE_TYPE...OK
Writing file 6 of 7: PTABLE_CUST...OK
Software written
2020-04-28 09:57:49 start to update preload
File to update: C:\Users\Abdoulgaf\Desktop\MAR-L21\update_sd_preload_MAR-L21A_hw_eea_R2\UPDATE.APP
File size: 254*210*120 bytes
Current version(PRELOAD_VER): MAR_GLOBAL_PRELOAD 9.0.1(C999)
Process identifier:24137265
Validating file...
Writing file 3 of 7: PRELOAD_VERLIST...OK
Writing file 4 of 7: PRELOAD_VER...OK
Writing file 6 of 7: PTABLE_PRELOAD...OK
Software written
2020-04-28 09:57:59 start to write update file
Process identifier:24137274
Validating file...
Writing file 7 of 46: XLOADER...OK
Writing file 8 of 46: FASTBOOT...OK
Writing file 9 of 46: HHEE...OK
Writing file 10 of 46: DTS...OK
Writing file 11 of 46: TRUSTFIRMWARE...OK
Writing file 12 of 46: FW_LPM3...OK
Writing file 13 of 46: DTO...OK
Writing file 14 of 46: KERNEL...OK
Writing file 15 of 46: TEEOS...OK
Writing file 16 of 46: ISP_FIRMWARE...OK
Writing file 17 of 46: VECTOR...OK
Writing file 18 of 46: SENSORHUB...OK
Writing file 19 of 46: FW_HIFI...OK
Writing file 20 of 46: VBMETA...OK
Writing file 21 of 46: MODEMNVM_UPDATE...OK
Writing file 22 of 46: MODEMNVM_CUST...OK
Writing file 23 of 46: RECOVERY_RAMDISK...OK
Writing file 24 of 46: RECOVERY_VENDOR...OK
Writing file 25 of 46: RECOVERY_VBMETA...OK
Writing file 26 of 46: PREAS...OK
Writing file 27 of 46: PREAVS...OK
Writing file 28 of 46: ERECOVERY_KERNEL...OK
Writing file 29 of 46: ERECOVERY_RAMDISK...OK
Writing file 30 of 46: ERECOVERY_VENDOR...OK
Writing file 31 of 46: ERECOVERY_VBMETA...OK
Writing file 32 of 46: ENG_VENDOR...OK
Writing file 33 of 46: ENG_SYSTEM...OK
Writing file 34 of 46: CACHE...OK
Writing file 35 of 46: SYSTEM...OK
Writing file 36 of 46: CUST...OK
Writing file 37 of 46: MODEM_FW...OK
Writing file 38 of 46: HISEE_IMG...OK
Writing file 39 of 46: HISEE_FS...OK
Writing file 40 of 46: VENDOR...OK
Writing file 41 of 46: ODM...OK
Writing file 42 of 46: PRODUCT...OK
Writing file 43 of 46: PATCH...OK
Writing file 44 of 46: USERDATA...OK
Writing file 45 of 46: VERSION...OK
Writing file 46 of 46: PRELOAD...OK
Software written
2020-04-28 10:07:59 start to update cust file
Process identifier:24137597
Validating file...
Writing file 7 of 7: VERSION...OK
Software written
2020-04-28 10:08:07 start to update preload
Process identifier:24137603
Validating file...
Writing file 7 of 7: PRELOAD...OK
Software written
2020-04-28 10:08:58 Writing device finished OK
The Following 3 Users Say Thank You to abdoulgaf For This Useful Post:
Old 04-28-2020, 11:15   #45 (permalink)
Member: 1813429
Thanks Meter: 11
now how to bypass frp sir?
Page generated in 0.27438 seconds with 8 queries
