07-02-2020, 13:19 | #1 (permalink) |
No Life Poster Join Date: Feb 2003 Location: Somewhere
Member: 22466 Status: Offline Thanks Meter: 282 | STK-L21 downgrade problem Code: DC Phoenix 0.0.0.132 File size: 3,805,062,084 bytes Current version(BASE_VER): STK-LGRP2-OVS 9.0.1.170 Package Type: OFFLINE_UPDATE Revision: 1 Checking partition: BASE_VERLIST With this update file it is necessary to select CUST file and if it exists, PRELOAD file. File size: 254,201,000 bytes Current version(PRELOAD_VER): STK_GLOBAL_PRELOAD 9.0.1(C999) Package Type: OFFLINE_UPDATE Checking partition: PRELOAD_VERLIST File size: 554,596 bytes Current version(CUST_VER): STK-LX1-CUST 9.1.0.1(C431) Package Type: OFFLINE_UPDATE Checking partition: CUST_VERLIST DC Phoenix 0.0.0.132 Standard update Not Reboot NOT cheked Update Verlist to server on file load NOT checked Try Rescue Recovery checked Bypass version check checked Old slow algo NOT checked Looking for a device in upgrade mode No devices detected in upgrade mode Device found: MVS4C20113011465 Detecting recovery partition File size: 3,805,062,084 bytes Current version(BASE_VER): STK-LGRP2-OVS 9.0.1.170 ERECOVERY_KERNEL partition found ERECOVERY_RAMDISK partition found ERECOVERY_VENDOR partition found 7/2/2020 2:50:27 PM Starting to try Rescue Recovery... Looking for a device in fastboot mode Device found: MVSxxxxxxx Getting IMEI... Getting build number... Getting model ... Getting battery state... Getting backdoor info... Getting lock state info... Getting lock boot info... Build number: :STK-L21 10.0.0.196(C431E8R1P2) Model: STK-LX1 Vendor/Country: hw/eea Battery state: 3748mv OEM lock state info: FB LockState: LOCKED USER LockState: LOCKED OEM get bootinfo: locked Getting base version... Base Version: STK-LGRP2-OVS 10.0.0.196 Getting cust version... Cust Version: STK-L21-CUST 10.0.0.8(C431) Getting preload version... Preload Version: STK-LX1-PRELOAD 10.0.0.2(C431R1) Process identifier:25655264 Erasing ver .. . File size: 3,805,062,084 bytes Current version(BASE_VER): STK-LGRP2-OVS 9.0.1.170 Writing rescue_recovery_kernel partition RESCUE_RECOVERY_KERNEL partition update ...OK Writing rescue_recovery_ramdisk partition RESCUE_RECOVERY_RAMDISK partition update ...OK Writing rescue_recovery_vendor partition RESCUE_RECOVERY_VENDOR partition update ...OK Uptade recovery parttion OK USB Device REMOVAL Type: @oem14.inf,%tplinkfastboot%;Android Bootloader Interface VidPid: VID_18D1&PID_D00D Instance id: 5&1d73674e&0&1 Looking for device in upgrade mode... USB Device INSERTION Type: @oem16.inf,%busfilter.devicedesc%;USB Composite Device VidPid: VID_12D1&PID_107E Instance id: 5&1d73674e&0&1 COM6: Android Adapter PCUI (COM6) COM7: DBAdapter Reserved Interface (COM7) Enter recovery mode OK 7/2/2020 2:51:15 PM Starting to write device in UPGRADE mode... Device found: MVS4C20113011465 Old slow algo NOT selected 7/2/2020 2:51:18 PM start to write update file File to update: D:\DC\- Flash\STK-L21\dload\UPDATE.APP File size: 3,805,062,084 bytes Current version(BASE_VER): STK-LGRP2-OVS 9.0.1.170 Process identifier:25655344 Validating file... Looking for attached port... Preparing to write... Bypass version checked Checking partition ... Writing file 1 of 44: SHA256RSA... Writing file 1 of 44: SHA256RSA...OK Writing file 2 of 44: CRC... Writing file 2 of 44: CRC...OK Writing file 3 of 44: BASE_VERLIST... Writing file 3 of 44: BASE_VERLIST...OK Writing file 4 of 44: BASE_VER... Writing file 4 of 44: BASE_VER...OK Writing file 5 of 44: PACKAGE_TYPE... Writing file 5 of 44: PACKAGE_TYPE...OK Writing file 6 of 44: HISIUFS_GPT... Writing file 6 of 44: HISIUFS_GPT...OK Software written 7/2/2020 2:51:35 PM start to update cust file File to update: D:\DC\- Flash\STK-L21\dload\STK-L21_hw\update_sd_cust_STK-L21_hw_eea\UPDATE.APP File size: 554,596 bytes Current version(CUST_VER): STK-LX1-CUST 9.1.0.1(C431) Process identifier:25655423 Validating file... Looking for attached port... Preparing to write... Bypass version checked Checking partition ... Writing file 1 of 7: SHA256RSA... Writing file 1 of 7: SHA256RSA...OK Writing file 2 of 7: CRC... Writing file 2 of 7: CRC...OK Writing file 3 of 7: CUST_VERLIST... Error downloading file 3 of 7 Error writing software 7/2/2020 2:51:55 PM Writing device finished with ERROR |
07-07-2020, 15:00 | #4 (permalink) |
Product Supporter Join Date: Sep 2013 Location: Lithuania, Kaunas
Member: 2023196 Status: Offline Thanks Meter: 1,891 | Please do this: 1. Restart DC-Phoenix. 2. Press CTRL+L 3. Select firmware and flash 4. After unsuccessful flashing close DC-phoenix 5. Open directory where DC-phoenix software is placed in 6. Look for .dgtkl file there, send it to me, please |
07-07-2020, 15:26 | #5 (permalink) | |
Member: 22466 Status: Offline Thanks Meter: 282 | Quote:
pls check PM alex | |
07-07-2020, 19:24 | #6 (permalink) |
No Life Poster Join Date: Nov 2010 Location: RSA-2048 Age: 38
Member: 1444462 Status: Offline Thanks Meter: 1,337 | I have successfully downgraded from STK-LGRP3-OVS 10.0.0.185(C316) to STK-LGRP3-OVS 9.0.1.170(C316) by fast bootmode. DC Phoenix 0.0.0.132 Standard update Not Reboot NOT cheked Update Verlist to server on file load NOT checked Try Rescue Recovery checked Bypass version check checked Old slow algo NOT checked Looking for a device in upgrade mode No devices detected in upgrade mode Device found: RSV4C19923002920 Detecting recovery partition File size: 3,763,867,744 bytes Current version(BASE_VER): STK-LGRP3-OVS 9.0.1.170 ERECOVERY_KERNEL partition found ERECOVERY_RAMDISK partition found ERECOVERY_VENDOR partition found 7/7/2020 6:12:08 PM Starting to try Rescue Recovery... Looking for a device in fastboot mode Device found: RSV4C19923002920 Getting IMEI... Getting build number... Getting model ... Getting battery state... Getting backdoor info... Getting lock state info... Getting lock boot info... Build number: :STK-L21M 9.1.0.307(C185E2) Model: STK-L21 Vendor/Country: vodacom/za Battery state: 4165mv OEM lock state info: FB LockState: LOCKED USER LockState: LOCKED OEM get bootinfo: locked Getting base version... Base Version: STK-LGRP3-OVS 10.0.0.185 Getting cust version... Cust Version: STK-L01M-CUST 10.0.0.4(C316) Getting preload version... Preload Version: STK-L01-PRELOAD 10.0.0.1(C316R4) Process identifier:25784212 Erasing ver .. . File size: 3,763,867,744 bytes Current version(BASE_VER): STK-LGRP3-OVS 9.0.1.170 Writing rescue_recovery_kernel partition RESCUE_RECOVERY_KERNEL partition update ...OK Writing rescue_recovery_ramdisk partition RESCUE_RECOVERY_RAMDISK partition update ...OK Writing rescue_recovery_vendor partition RESCUE_RECOVERY_VENDOR partition update ...OK Uptade recovery parttion OK USB Device REMOVAL Type: @oem66.inf,%hwfastboot%;Android Sooner Single ADB Interface VidPid: VID_18D1&PID_D00D Instance id: 6&56ec216&0&3 Looking for device in upgrade mode... USB Device INSERTION Type: @oem70.inf,%busfilter.devicedesc%;USB Composite Device VidPid: VID_12D1&PID_107E Instance id: RSV4C19923002920 COM85: Android Adapter PCUI (COM85) COM84: DBAdapter Reserved Interface (COM84) Enter recovery mode OK 7/7/2020 6:12:50 PM Starting to write device in UPGRADE mode... Device found: RSV4C19923002920 Old slow algo NOT selected 7/7/2020 6:12:53 PM start to write update file File to update: C:\Users\hp\Downloads\Compressed\STK-L01M (C316) Downgrade From 10.0.0 To 9.1.0 and Fix Hang On eRecovery\STEP2\STEP2-Update.APP File size: 3,763,867,744 bytes Current version(BASE_VER): STK-LGRP3-OVS 9.0.1.170 Process identifier:25784272 Validating file... Looking for attached port... Preparing to write... Bypass version checked Checking partition ... Writing file 1 of 41: SHA256RSA...OK Writing file 2 of 41: CRC...OK Writing file 3 of 41: BASE_VERLIST...OK Writing file 4 of 41: BASE_VER...OK Writing file 5 of 41: PACKAGE_TYPE...OK Writing file 6 of 41: HISIUFS_GPT...OK Software written 7/7/2020 6:13:11 PM start to update cust file File to update: C:\Users\hp\Downloads\Compressed\STK-L01M (C316) Downgrade From 10.0.0 To 9.1.0 and Fix Hang On eRecovery\STEP2\STEP2-Customization.APP File size: 9,980,520 bytes Current version(CUST_VER): STK-L21-CUST 9.1.0.1(C00) Process identifier:25784286 Validating file... Looking for attached port... Preparing to write... Bypass version checked Checking partition ... Writing file 1 of 7: SHA256RSA...OK Writing file 2 of 7: CRC...OK Writing file 3 of 7: CUST_VERLIST...OK Writing file 4 of 7: CUST_VER...OK Writing file 5 of 7: PACKAGE_TYPE...OK Writing file 6 of 7: PTABLE_CUST...OK Software written 7/7/2020 6:13:29 PM start to update preload File to update: C:\Users\hp\Downloads\Compressed\STK-L01M (C316) Downgrade From 10.0.0 To 9.1.0 and Fix Hang On eRecovery\STEP2\STEP2-Preload.APP File size: 199,270,592 bytes Current version(PRELOAD_VER): STK_GLOBAL_PRELOAD 9.0.1(C316) Process identifier:25784305 Validating file... Looking for attached port... Preparing to write... Bypass version checked Checking partition ... Writing file 1 of 7: SHA256RSA...OK Writing file 2 of 7: CRC...OK Writing file 3 of 7: PRELOAD_VERLIST...OK Writing file 4 of 7: PRELOAD_VER...OK Writing file 5 of 7: PACKAGE_TYPE...OK Writing file 6 of 7: PTABLE_PRELOAD...OK Software written 7/7/2020 6:13:46 PM start to write update file File to update: C:\Users\hp\Downloads\Compressed\STK-L01M (C316) Downgrade From 10.0.0 To 9.1.0 and Fix Hang On eRecovery\STEP2\STEP2-Update.APP File size: 3,763,867,744 bytes Current version(BASE_VER): STK-LGRP3-OVS 9.0.1.170 Process identifier:25784329 Validating file... Looking for attached port... Preparing to write... Bypass version checked Checking partition ... Writing file 1 of 41: SHA256RSA...OK Writing file 2 of 41: CRC...OK Writing file 3 of 41: BASE_VERLIST...OK Writing file 4 of 41: BASE_VER...OK Writing file 5 of 41: PACKAGE_TYPE...OK Writing file 6 of 41: HISIUFS_GPT...OK Writing file 7 of 41: XLOADER...OK Writing file 8 of 41: FASTBOOT...OK Writing file 9 of 41: HHEE...OK Writing file 10 of 41: DTS...OK Writing file 11 of 41: TRUSTFIRMWARE...OK Writing file 12 of 41: FW_LPM3...OK Writing file 13 of 41: DTO...OK Writing file 14 of 41: KERNEL...OK Writing file 15 of 41: TEEOS...OK Writing file 16 of 41: ISP_FIRMWARE...OK Writing file 17 of 41: VECTOR...OK Writing file 18 of 41: SENSORHUB...OK Writing file 19 of 41: FW_HIFI...OK Writing file 20 of 41: VBMETA...OK Writing file 21 of 41: MODEMNVM_UPDATE...OK Writing file 22 of 41: MODEMNVM_CUST...OK Writing file 23 of 41: RECOVERY_RAMDISK...OK Writing file 24 of 41: RECOVERY_VENDOR...OK Writing file 25 of 41: RECOVERY_VBMETA...OK Writing file 26 of 41: ERECOVERY_KERNEL...OK Writing file 27 of 41: ERECOVERY_RAMDISK...OK Writing file 28 of 41: ERECOVERY_VENDOR...OK Writing file 29 of 41: ERECOVERY_VBMETA...OK Writing file 30 of 41: ENG_VENDOR...OK Writing file 31 of 41: ENG_SYSTEM...OK Writing file 32 of 41: CACHE...OK Writing file 33 of 41: SYSTEM...OK Writing file 34 of 41: CUST...OK Writing file 35 of 41: MODEM_FW...OK Writing file 36 of 41: HISEE_IMG...OK Writing file 37 of 41: HISEE_FS...OK Writing file 38 of 41: VENDOR...OK Writing file 39 of 41: ODM...OK Writing file 40 of 41: PRODUCT...OK Writing file 41 of 41: USERDATA...OK Software written 7/7/2020 6:21:43 PM start to update cust file File to update: C:\Users\hp\Downloads\Compressed\STK-L01M (C316) Downgrade From 10.0.0 To 9.1.0 and Fix Hang On eRecovery\STEP2\STEP2-Customization.APP File size: 9,980,520 bytes Current version(CUST_VER): STK-L21-CUST 9.1.0.1(C00) Process identifier:25784678 Validating file... Looking for attached port... Preparing to write... Bypass version checked Checking partition ... Writing file 1 of 7: SHA256RSA...OK Writing file 2 of 7: CRC...OK Writing file 3 of 7: CUST_VERLIST...OK Writing file 4 of 7: CUST_VER...OK Writing file 5 of 7: PACKAGE_TYPE...OK Writing file 6 of 7: PTABLE_CUST...OK Writing file 7 of 7: VERSION...OK Software written 7/7/2020 6:22:00 PM start to update preload File to update: C:\Users\hp\Downloads\Compressed\STK-L01M (C316) Downgrade From 10.0.0 To 9.1.0 and Fix Hang On eRecovery\STEP2\STEP2-Preload.APP File size: 199,270,592 bytes Current version(PRELOAD_VER): STK_GLOBAL_PRELOAD 9.0.1(C316) Process identifier:25784690 Validating file... Looking for attached port... Preparing to write... Bypass version checked Checking partition ... Writing file 1 of 7: SHA256RSA...OK Writing file 2 of 7: CRC...OK Writing file 3 of 7: PRELOAD_VERLIST...OK Writing file 4 of 7: PRELOAD_VER...OK Writing file 5 of 7: PACKAGE_TYPE...OK Writing file 6 of 7: PTABLE_PRELOAD...OK Writing file 7 of 7: PRELOAD...OK Software written 7/7/2020 6:22:46 PM Writing device finished OK |
