Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > DC Unlocker
Old 12-19-2018, 07:58   #16 (permalink)
Member: 2023196
Thanks Meter: 1,422
Originally Posted by abdoulgaf View Post
please make a video on how to use this new version.
You select bootloader of your mobile according to it's processor, you select oem info with correct data entered and you press update. Then you flash corresponding firmware/customization file into your mobile matching oeminfo data that you entered before pressing update. As warning mentions this is only for advanced users.
The Following User Says Thank You to Namelocked For This Useful Post:
Old 12-19-2018, 08:01   #17 (permalink)
Member: 2023196
Thanks Meter: 1,422
Originally Posted by salye View Post
how to choose bootloader T0-T3 V1-V5
T0-T2 shows security level of loader, V1-V5 just shows version number of same loader (most likely with different security, android version or just from different mobile that runs same processor).
Old 12-19-2018, 08:02   #18 (permalink)
Member: 2023196
Thanks Meter: 1,422
Originally Posted by rishes View Post
2018-12-19 10:33:45.299 Erase FRP start
2018-12-19 10:33:45.675 Connecting to server...
2018-12-19 10:33:46.216 Connected!
2018-12-19 10:33:47.352 Reading phone info...
2018-12-19 10:33:47.894 Read phone info success!
Model: HUAWEI CRO-U00
Firmware ver.: Cairo-U00C636B126
SN: CAX9K18904904341
2018-12-19 10:33:47.941 Phone info data backup saved to file C:\Users\rishes\Desktop\DC_Phoenix_v52\HCU_257\Bac kup\20181219_103347_CAX9K18904904341.BAK
2018-12-19 10:33:48.129 Reading FRP certify data...
2018-12-19 10:33:48.313 Read FRP certify fail!
2018-12-19 10:33:48.313 Erase FRP fail!
unknown responce!
That one is not supported yet.
Old 12-19-2018, 08:10   #19 (permalink)
lhl
Member: 17822
Thanks Meter: 3
Pleas add support for LON-L29C 8.0.0.377(C185) bootloader file and oeminfo file.
thanks!
Old 12-19-2018, 10:11   #20 (permalink)
Member: 2185549
Thanks Meter: 501
this means client is entitled to knw the boot type or cpu a phone uses can soome one rectify if wrnng boot option writen can phone brick or exe has capability to reject
Old 12-19-2018, 10:19   #21 (permalink)
Member: 2023196
Thanks Meter: 1,422
thanks!
Bootloader available, but oeminfo not. You may use your own if you have it though. May also try with MHA oeminfo.
Old 12-19-2018, 10:20   #22 (permalink)
Member: 2023196
Thanks Meter: 1,422
Writing boot won't brick device.
Old 12-19-2018, 10:55   #23 (permalink)
Member: 74756
Sonork: 100.1659084
Thanks Meter: 12
In what mode should the phone be connected to change the OEMINFO?
In normal mode with the Manufacture mode enabled?
Old 12-19-2018, 11:52   #24 (permalink)
Member: 2023196
Thanks Meter: 1,422
If you write bootloader (must do it for all new phones) Then you should start with testpoint as written in update info of software.
Old 12-19-2018, 11:52   #25 (permalink)
Member: 2023196
Thanks Meter: 1,422
thanks!
Now oeminfo files available for it too.
Old 12-19-2018, 11:53   #26 (permalink)
Member: 515130
Thanks Meter: 304
Lon-Al00 test point flashing fail
12/19/2018 4:50:03 PM Starting to write device in FASTBOOT mode...
File to update: LON-AL00_BM00A073_Board_Software_general_7.0.0_r1_EMUI 5.0_05022CDS.dgtks
Device detected:
COM333: HUAWEI USB COM 1.0 (COM333)
Writing bootloader...
Writing LON-AL00_BM00A073_Board_Software_general_7.0.0_r1_EMUI 5.0_05022CDS_3.dtwork...
Error writing Bootloader
12/19/2018 4:50:18 PM Writing device finished - INCOMPLETE
Old 12-19-2018, 11:56   #27 (permalink)
Member: 2023196
Thanks Meter: 1,422
Device detected:
Yes, not supported for board software flashing due to loader missmatch. You should refer to this guide's update info for instructions on how you can revive this mobile with new loader+oeminfo method.
Old 12-19-2018, 12:15   #28 (permalink)
Member: 515130
Thanks Meter: 304
Thanks for fast reply
i am new user i want flash my phone i try via fastboot but phone not supported i think then i try via TP but not flash how can i flash my phone i need some info
Old 12-19-2018, 15:05   #29 (permalink)
Member: 2545420
have nova 3i INE-LX1 how ca i remove demo ??
Old 12-19-2018, 15:27   #30 (permalink)
Member: 738323
Sonork: 1618038
Thanks Meter: 68
Looking for a device in upgrade mode
No devices detected in upgrade mode
Device found: WCR7N1861200
19/12/2018 9:51:12 a. m. Starting to write device in FASTBOOT mode...
Looking for a device in fastboot mode
Device found: WCR7N18612008594
SN:WCR7N18612xxxxxxx
IMEI:86726003
IMEI1:86726003
MEID:A000008C42075C
Build number: :CLT-L29 8.0.0.106(C432)
Model: CLT-L29
Battery state: 6606mv
Device with unsupported security patch
User accepted to update device with unsupported security patch
Extracting partition XLOADER...
Erasing XLOADER partition
Partition XLOADER erased
Writing XLOADER partition
XLOADER partition UPDATE ...OK
Extracting partition FW_LPM3...
Erasing FW_LPM3 partition
Partition FW_LPM3 erased
Writing FW_LPM3 partition
FW_LPM3 partition UPDATE ...OK
Extracting partition HHEE...
Erasing HHEE partition
Partition HHEE erased
Writing HHEE partition
HHEE partition UPDATE ...OK
Extracting partition FASTBOOT...
Erasing FASTBOOT partition
Partition FASTBOOT erased
Writing FASTBOOT partition
FASTBOOT partition UPDATE ...OK
Extracting partition VECTOR...
Erasing VECTOR partition
Partition VECTOR erased
Writing VECTOR partition
VECTOR partition UPDATE ...OK
Extracting partition VBMETA...
Erasing VBMETA partition
Partition VBMETA erased
Writing VBMETA partition
VBMETA partition UPDATE ...OK
Extracting partition MODEMNVM_UPDATE...
Erasing MODEMNVM_UPDATE partition
Partition MODEMNVM_UPDATE erased
Writing MODEMNVM_UPDATE partition
MODEMNVM_UPDATE partition UPDATE ...OK
Extracting partition MODEMNVM_CUST...
Erasing MODEMNVM_CUST partition
Partition MODEMNVM_CUST erased
Writing MODEMNVM_CUST partition
MODEMNVM_CUST partition UPDATE ...OK
Extracting partition TEEOS...
Erasing TEEOS partition
Partition TEEOS erased
Writing TEEOS partition
TEEOS partition UPDATE ...OK
Extracting partition TRUSTFIRMWARE...
Erasing TRUSTFIRMWARE partition
Partition TRUSTFIRMWARE erased
Writing TRUSTFIRMWARE partition
TRUSTFIRMWARE partition UPDATE ...OK
Extracting partition SENSORHUB...
Erasing SENSORHUB partition
Partition SENSORHUB erased
Writing SENSORHUB partition
SENSORHUB partition UPDATE ...OK
Extracting partition FW_HIFI...
Erasing FW_HIFI partition
Partition FW_HIFI erased
Writing FW_HIFI partition
FW_HIFI partition UPDATE ...OK
Extracting partition KERNEL...
Erasing KERNEL partition
Partition KERNEL erased
Writing KERNEL partition
KERNEL partition UPDATE ...OK
Extracting partition RAMDISK...
Erasing RAMDISK partition
Partition RAMDISK erased
Writing RAMDISK partition
RAMDISK partition UPDATE ...OK
Extracting partition RECOVERY_RAMDISK...
Erasing RECOVERY_RAMDISK partition
Partition RECOVERY_RAMDISK erased
Writing RECOVERY_RAMDISK partition
RECOVERY_RAMDISK partition UPDATE ...OK
Extracting partition RECOVERY_VENDOR...
Erasing RECOVERY_VENDOR partition
Partition RECOVERY_VENDOR erased
Writing RECOVERY_VENDOR partition
RECOVERY_VENDOR partition UPDATE ...OK
Extracting partition RECOVERY_VBMETA...
Erasing RECOVERY_VBMETA partition
Partition RECOVERY_VBMETA erased
Writing RECOVERY_VBMETA partition
RECOVERY_VBMETA partition UPDATE ...OK
Extracting partition ERECOVERY_KERNEL...
Erasing ERECOVERY_KERNEL partition
Partition ERECOVERY_KERNEL erased
Writing ERECOVERY_KERNEL partition
ERECOVERY_KERNEL partition UPDATE ...OK
Extracting partition ERECOVERY_RAMDISK...
Erasing ERECOVERY_RAMDISK partition
Partition ERECOVERY_RAMDISK erased
Writing ERECOVERY_RAMDISK partition
ERECOVERY_RAMDISK partition UPDATE ...OK
Extracting partition ERECOVERY_VENDOR...
Erasing ERECOVERY_VENDOR partition
Partition ERECOVERY_VENDOR erased
Writing ERECOVERY_VENDOR partition
ERECOVERY_VENDOR partition UPDATE ...OK
Extracting partition ERECOVERY_VBMETA...
Erasing ERECOVERY_VBMETA partition
Partition ERECOVERY_VBMETA erased
Writing ERECOVERY_VBMETA partition
ERECOVERY_VBMETA partition UPDATE ...OK
Extracting partition HDCP...
Erasing HDCP partition
Partition HDCP erased
Writing HDCP partition
HDCP partition UPDATE ...OK
Extracting partition DTS...
Erasing DTS partition
Partition DTS erased
Writing DTS partition
DTS partition UPDATE ...OK
Extracting partition DTO...
Erasing DTO partition
Partition DTO erased
Writing DTO partition
DTO partition UPDATE ...OK
Extracting partition CACHE...
Erasing CACHE partition
Partition CACHE erased
Writing CACHE partition
CACHE partition UPDATE ...OK
Extracting partition SYSTEM...
Erasing SYSTEM partition
ERASE partition SYSTEM :
Writing SYSTEM partition
sending sparse file 471859199 bytes
long time and does not happen there is? more 40 minutes what will be the problem?
Page generated in 0.37260 seconds with 8 queries
