Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > DC Unlocker
Old 01-04-2020, 09:41   #1 (permalink)
Member: 2742707
Thanks Meter: 74
DUB-LX1 8.2.0.142(C185) USB Device REMOVAL / Cannot Flash
Looking for a device in upgrade mode
No devices detected in upgrade mode
Device found: DYN6R19827000640
Detecting recovery partition
File size: 3,854,012,100 bytes
AMSS version: DUB-L22 8.2.0.173(C900)
ERECOVERY_KERNEL partition found
ERECOVERY_RAMDISK partition found
ERECOVERY_VENDOR partition found
1/4/2020 10:36:58 AM Starting to try Rescue Recovery...
Looking for a device in fastboot mode
Getting IMEI...
Getting build number...
Getting model ...
Getting battery state...
Getting backdoor info...
Getting lock state info...
Getting lock boot info...
Build number: DUB-LX1 8.2.0.142(C185)
Model: DUB-LX1
Vendor/Country: Vendor/Country: hw/meafnaf
Battery state: 3710mv
OEM lock state info:
user Lock state is lock
fbLock state is lock
OEM get bootinfo:
Image is origin
Verify mode is enforcing
Check root info is safe
Lock state is lock
Root State: UNROOT
Process identifier:21878210
Getting base version...
Getting cust version...
Getting preload version...
Erasing ver .. .
Writing rescue_recovery_kernel partition
RESCUE_RECOVERY_KERNEL partition update ...OK
Writing rescue_recovery_ramdisk partition
RESCUE_RECOVERY_RAMDISK partition update ...OK
Writing rescue_recovery_vendor partition
RESCUE_RECOVERY_VENDOR partition update ...OK
Looking for device in upgrade mode...
USB Device REMOVAL
Type: @oem23.inf,%singlebootloaderinterface%;Android Bootloader Interface
VidPid: VID_18D1&PID_D00D
Instance id: DYN6R19827000640
The Following User Says Thank You to ...::S.L.S::... For This Useful Post:
Old 01-06-2020, 16:29   #2 (permalink)
Member: 2023196
Thanks Meter: 1,249
So what happens when you follow the guide, put it manually in necessary mode and continue flashing?
Old 01-06-2020, 22:40   #3 (permalink)
Member: 1209155
Thanks Meter: 41
Flash in Edl Mode using XML firmware xtracted from App file
Page generated in 0.25628 seconds with 7 queries
