Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > DC Unlocker
Old 12-04-2017, 09:11   #31 (permalink)
Member: 2023196
Thanks Meter: 1,410
Originally Posted by aliusmanbava View Post
12/4/2017 12:27:30 PM Starting to write device in FASTBOOT mode...
File to update: CHM-U01_MAA001057_Factory_firmware_Europe_Android_4.4. 2_EMUI_3.0.dgtks
No devices detected in force upgrade mode
And how is your phone visible in device manager please?
The Following User Says Thank You to Namelocked For This Useful Post:
Old 12-04-2017, 11:20   #32 (permalink)
Member: 735442
Sonork: luca80pa
i have two problem today....hcu don't connect to server and now i have downloaded dcphoenix but when i want run it show me disk not present in D:
Can you help me?
Old 12-04-2017, 12:13   #33 (permalink)
Member: 2023196
Thanks Meter: 1,410
Can you help me?
Yes, servers undergoing maintenance, no exact eta on when it will be online. Sorry for inconvenience.
Do not quite understand the other problem, maybe could add screenshot?
Old 12-04-2017, 12:24   #34 (permalink)
Member: 1886712
Thanks Meter: 46
HUAWEI USB COME 1.0
i try with DC_Phoenix_v32 but error
Writing bootloader...
Writing CHM-U01_MAA001057_Factory_firmware_Europe_Android_4.4. 2_EMUI_3.0_3.dtwork...
Writing CHM-U01_MAA001057_Factory_firmware_Europe_Android_4.4. 2_EMUI_3.0_4.dtwork...
12/4/2017 2:12:04 PM Writing device finished - INCOMPLETE
Old 12-04-2017, 13:07   #35 (permalink)
Member: 2094323
Hi,
Cannot get this Version (0208) to run in Win 10 pro, latest updates.
Besides Win Defender stopping it (Trojan Warning) even when I disable defender I get a message “The application was unable to start correctly (0xc0150002), Click OK to close the application.”
Any suggestions, please?
TIA
Old 12-04-2017, 13:10   #36 (permalink)
Member: 2023196
Thanks Meter: 1,410
HUAWEI USB COME 1.0
Try with latest one.
Old 12-04-2017, 13:11   #37 (permalink)
Member: 2023196
Thanks Meter: 1,410
Originally Posted by Sparkrite View Post
Hi,
TIA
Yes, update windows - https://www.microsoft.com/en-us/down...id=26347%20%20 if not working check online what that windows error that you get means and what update it requires.
Old 12-04-2017, 13:34   #38 (permalink)
Member: 1886712
Thanks Meter: 46
i try already DC_Phoenix_v45
but phone not connect dead mode
Old 12-04-2017, 14:16   #39 (permalink)
Member: 2023196
Thanks Meter: 1,410
Then contact us via live support chat.
Old 12-04-2017, 17:13   #40 (permalink)
Member: 2094323
Yes, update windows - if not working check online what that windows error that you get means and what update it requires.
Thanks for reply, and there was indeed an update, checked 2 days ago, wasn't there then. This was a big update, and I hate the way MS just secretly re-partition your drive.
Anyway after update completed (eventually) and I also manually update C++ I am still getting the same error (0xc0150002), also Defender reports a trojan, but the strange thing is it will run on my old XP machine.
Also some of the older versions (hard to find) run on my Win10 machine.
Do you have a link for the old 0199 version, please? Just to see if that will run.
TIA.
Old 12-05-2017, 08:19   #41 (permalink)
Member: 2023196
Thanks Meter: 1,410
TIA.
No sorry, had only this one. It helped for all other users, might be some changes in windows updates then. Make sure you restart PC after updating package from link i gave, maybe it did not apply.
Old 12-06-2017, 21:44   #42 (permalink)
Member: 1881160
Thanks Meter: 3
with every update HCU works worse, changing the number of imei in the android system shows changed imei, but with the command fastboot shows the old imei. Typing for example at the end imei 1 changes to 5; /
https://www.youtube.com/watch?v=Y55nBIAeSJw&fs=1" width="644" height="390">https://www.youtube.com/watch?v=Y55nBIAeSJw&fs=1" />https://www.youtube.com/watch?v=Y55nBIAeSJw">http://www.youtube.com/watch?v=https://www.youtube.com/watch?v=Y55nBIAeSJw
Old 12-06-2017, 21:46   #43 (permalink)
Member: 1881160
Thanks Meter: 3
TIA.
Install https://www.microsoft.com/en-us/down...n.aspx?id=5555
Old 12-06-2017, 21:49   #44 (permalink)
selective member DC - Unlocker
Member: 3431
Thanks Meter: 12,169
Please make factory reset , can i know what problems you have with HCU?
Old 12-06-2017, 22:20   #45 (permalink)
Member: 1881160
Thanks Meter: 3
Look, change imei in Manufacture mode run factory reset, press *#06# imei has changed, shutdown phone disconnect usb kable, press vol - connect to pc, and read imei in HCU "Read phone info" imei is old but in android is new imei o.0
in fact, the imei number is not changed, after version 174 problems started, I wrote with your support, I got a range betatester but it has not been repaired
Page generated in 0.36800 seconds with 8 queries
