Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > DC Unlocker
Old 12-06-2017, 22:34   #46 (permalink)
selective member DC - Unlocker
Member: 3431
Thanks Meter: 12,169
Originally Posted by krzychunh View Post
Look, change imei in Manufacture mode run factory reset, press *#06# imei has changed, shutdown phone disconnect usb kable, press vol - connect to pc, and read imei in HCU "Read phone info" imei is old but in android is new imei o.0
in fact, the imei number is not changed, after version 174 problems started, I wrote with your support, I got a range betatester but it has not been repaired
Follow factory you need rewrite firmware after any rework, but you can solve this by press factory reset manually. And there not a fact not repaired, just no factory reset .
Old 12-06-2017, 23:13   #47 (permalink)
Member: 3431
Also before this version (about 174) hcu has wrong reset method (not as factory) and failing (if huawei account in phone, vendor country wrong or other reasons) for many users. Now HCU Huawei repair is same as factory.
Can i know any other problems ?
Old 12-07-2017, 08:35   #48 (permalink)
Member: 1881160
Thanks Meter: 3
I repeat the phone has been restored to factory settings, uploading new software does not improve anything, the problem still occurs, this is the HCU problem. I've tested on 20 phones with android 7
Old 12-07-2017, 08:37   #49 (permalink)
Member: 1881160
Thanks Meter: 3
Phone after loading imei sam restore the factory settings, manually also tried the problem remains in fastboot imei is old but in the android is changed
imei should be completely changed and he only overlaps
Old 12-07-2017, 13:00   #50 (permalink)
Member: 2094323
Install... (Link removed, not enough posts)
Thank you, but I have installed and uninstalled EVERY VB C++ from 2005-2017
but still the same error !! “The application was unable to start correctly (0xc0150002), Click OK to close the application.”
Its doing my head in especially that it runs on my old XP machine.
Old 12-07-2017, 13:32   #51 (permalink)
Member: 2023196
Thanks Meter: 1,410
How about this one https://www.microsoft.com/en-us/down...ion.aspx?id=29
The Following User Says Thank You to Namelocked For This Useful Post:
Old 12-07-2017, 13:57   #52 (permalink)
Member: 1881160
Thanks Meter: 3
install "c++ 2008 redistributable x86" "c++ 2008 redistributable x64" "you need install 2008 version"
The Following User Says Thank You to krzychunh For This Useful Post:
Old 12-07-2017, 14:11   #53 (permalink)
Member: 2094323
Success! Thank you very much. Both Namelocked and krzychunh.
That is strange but your link is the exact same file as krzychunh linked me to, but I uninstalled his and installed yours and it works, don't know how but it does.
BTW. I still have to disable "Win. Defender" as it complains about HCU containing a trojan.
Also for some reason I lost 3 credits even though I did nothing, perhaps Namelocked could look at this for me, please?
I can supply the log if needed.
Again thank you to you both.
Cheers.
Old 12-07-2017, 14:56   #54 (permalink)
Member: 2023196
Thanks Meter: 1,410
Detection before repair on HCU
Repairing new IMEIs:
Top info before repair, bottom - after repair and reset:
Cheers.
If you let me know your username i will check.
Old 12-07-2017, 15:05   #55 (permalink)
Member: 2094323
Thanks Namelocked, my username is Sparkrite.
TIA.
Old 12-07-2017, 15:07   #56 (permalink)
Member: 2023196
Thanks Meter: 1,410
TIA.
Credits now added back to your account.
Old 12-07-2017, 15:16   #57 (permalink)
Member: 2094323
Excellent. Thank you.
Old 12-07-2017, 21:43   #58 (permalink)
Member: 1881160
Thanks Meter: 3
Its ok Android 6 but Android 7 problem look youtube
https://www.youtube.com/watch?v=w5al...ture=*********
Old 12-11-2017, 10:11   #59 (permalink)
Member: 1881160
Thanks Meter: 3
is it already known what is the cause ?, does not HCU support Android 7?
Old 12-12-2017, 15:24   #60 (permalink)
Member: 1881160
Thanks Meter: 3
HCU - problem Android 7
It is not possible to repair the IMEI number on Android 7.
Imei is changed in the android system, but this is an overlay only, because in the fastboot command there is an old IMEI and there is no possibility to change
Page generated in 0.39183 seconds with 8 queries
