11-23-2016, 07:45 | #1 (permalink) |
No Life Poster Join Date: May 2011 Location: WeChat : Razib_Dits
Member: 1582197 Status: Offline Sonork: Whatapps : Razibbsl Thanks Meter: 808 | hcu-client Unlock & IMEI Repair tutorial Huawei phone IMEI repair tutorial Put phone in manufacture mode. On dialpad type *#*#2846579#*#*, select “Project Menu”, “Background settings”, “USB ports settings”, “Manufacture mode”. Then connect it to PC and install drivers (If you do not have separate driver pack for your device, install HiSuite software). Step 1 Download HCU tool here Launch software Step 2 On “Account” tab enter your user name and password. Click “Check account” button and wait to be logged into the server Step 3 Press “Read phone info” button and wait until phone is fully detected Step 4 Select “Repair UMTS” tab Step 5 Read warning message. If you agree with terms and want to continue press “OK” if you do not wish to continue press “Cancel” Step 6 Put a check mark next to IMEI field Step 7 Write in correct phone IMEI number and press “Repair” Step 8 Wait for repair process to finish, then disconnect and restart mobile device |
11-23-2016, 07:48 | #2 (permalink) |
Member: 1582197 Status: Offline Sonork: Whatapps : Razibbsl Thanks Meter: 808 | Read bootloader code for Huawei phone Put phone in manufacture mode. On dialpad type *#*#2846579#*#*, select “Project Menu”, “Background settings”, “USB ports settings”, “Manufacture mode”. Then connect it to PC and install drivers (If you do not have separate driver pack for your device, install HiSuite software). Step 1 Download HCU tool here Launch software Step 2 On “Account” tab enter your user name and password. Click “Check account” button and wait to be logged into the server Step 3 Press “Read phone info” button and wait until phone is fully detected Step 4 Select “Unlock” tab Step 5 Press “Read Bootloader code” button and wait until code is provided on memo window |
