Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > DC Unlocker
Old 03-21-2017, 19:09   #16 (permalink)
Member: 1898834
Sonork: abdelhakim.ch
Thanks Meter: 14
this is the screen shots of the operation , you can't find this solution in ALL THE WEB apart from here.
The Following User Says Thank You to alsa754 For This Useful Post:
Old 03-23-2017, 20:12   #17 (permalink)
Member: 1898834
Thanks Meter: 14
please sir i have CANC432B100, how to repair to become CAN-L01C432...
Old 03-24-2017, 17:21   #18 (permalink)
Member: 1898834
Thanks Meter: 14
when i flash factory firmware the fone become caz-al10 CDMA, and after flash can-l01 fone become canc432 but without gsm mode, he ask for meid and esn not like gsm
Old 03-27-2017, 12:13   #19 (permalink)
Member: 2023196
Thanks Meter: 1,383
Flash update.app file in fastboot mode, then in upgrade mode, see if it makes any difference.
Old 03-27-2017, 12:48   #20 (permalink)
Member: 1898834
Thanks Meter: 14
i did it, but fone become CANC432 without L01, and in HCU fone detected as CDMA, with 2 imei
Old 03-27-2017, 13:24   #21 (permalink)
Member: 1898834
Thanks Meter: 14
and with *#06# it gives 3 line: MEID00000000, AESN:OOOOOO AND IMEI:0
Old 03-27-2017, 18:23   #22 (permalink)
Member: 1898834
Thanks Meter: 14
when i try upgrade it stops at file 3
Old 03-27-2017, 18:55   #23 (permalink)
Member: 1898834
Thanks Meter: 14
more screen shots to describe the problem
Old 03-28-2017, 16:45   #24 (permalink)
Member: 2023196
Thanks Meter: 1,383
Please try to flash your UPDATE.app file in fastboot first only then in upgrade mode.
Old 03-28-2017, 16:48   #25 (permalink)
Member: 1898834
Thanks Meter: 14
that what i have did sir, update.app in fastboot mode, then the same file in upgrade mode and it stops at file 3, i have tried can-l01c432b100 and b140 and b300
Old 03-28-2017, 16:51   #26 (permalink)
Member: 2023196
Thanks Meter: 1,383
Then we will check if another factory firmware file available for this phone model, will inform on this topic.
Old 03-28-2017, 16:59   #27 (permalink)
Member: 1898834
Thanks Meter: 14
thank you verry much sir, also i have activated CHU for one year, how can i use it in another PC please
Old 03-29-2017, 09:22   #28 (permalink)
Member: 625485
Thanks Meter: 6
Huawei_P9_Lite_VNS-TL00 backup send [email protected]
Old 03-29-2017, 16:25   #29 (permalink)
Member: 2023196
Thanks Meter: 1,383
Sadly but only 2 version of this phone factory firmwares are availble, both of them are on our support area. Maybe later will come up more for it. You may try to repair numbers via HCU for mobile, if hardware is capable it may function as it is.
You need to wait for 48h before can use HCU on another PC.
Old 03-29-2017, 17:50   #30 (permalink)
Member: 1898834
Thanks Meter: 14
ok, thank you sir i will try all updat.app in all different ways, and hope that you will find another factory firmware, in HCU simlock is unknown and only one imei can be repaired,factory firmware is unlocked and rooted so i will try twrp ..... thank you again
Page generated in 0.37568 seconds with 8 queries
