To Namelocked : This statement "Huawei Mate 10 Pro BLA-xxx upgraded to Android 8x not supported" means Android 8.1 and onwards it's not supported? |
Does it supports bootloader code reading for P20 PRO clt l29? (to remove demo mode) thank you |
Hi, HCU now failing at "Read Phone Secure Info" returns "Read Phone Info fail" and window with "Check if phone is in manufacturer or fastboot mode". This is with a LLD-L31 (Honor 9 Lite) all my other Huaweis are fine. Was working with older versions, certianly V....277 |
1. Restart HCU software. 2. Login with your account on software. 3. Right click on memo area make sure "enable debug logging" has a check mark. 4. Try to Detect your device, after error do rest of the steps 5. Right click on memo area and save "debug log file". 6. Send that file to me, please. can send it via private message to this topic link. |
Done, Thank you. Look forward to your reply. |
Any update on P20 Imei repair @Namelocked ? Sent from my SM-G965W using Tapatalk |
Strange one, the phone is in the correct config. with debugging enabled. It did work before, albeit in build 133, phone rom, that is. It was actually me that uploaded the files to you, so you could support it. Anything I can do to help? Cheers. |
Please add FRP code calculator only with IMEI! Thanks |
when Honor Note 10 will be added? Need change the region |
