Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > DC Unlocker
Old 08-01-2018, 14:21   #16 (permalink)
Member: 2784864
To Namelocked : This statement "Huawei Mate 10 Pro BLA-xxx upgraded to Android 8x not supported" means Android 8.1 and onwards it's not supported?
Old 08-01-2018, 15:46   #17 (permalink)
Member: 2023196
Thanks Meter: 1,398
Yes, that's correct.
The Following User Says Thank You to Namelocked For This Useful Post:
Old 09-05-2018, 13:00   #18 (permalink)
Member: 1520741
Sonork: zboubdepanda
Thanks Meter: 65
Does it supports bootloader code reading for P20 PRO clt l29? (to remove demo mode)
thank you
Old 09-05-2018, 13:06   #19 (permalink)
Member: 2023196
Thanks Meter: 1,398
thank you
No, at the moment it does not.
Old 09-09-2018, 21:45   #20 (permalink)
Member: 2094323
Hi,
HCU now failing at "Read Phone Secure Info" returns "Read Phone Info fail" and window with "Check if phone is in manufacturer or fastboot mode".
This is with a LLD-L31 (Honor 9 Lite) all my other Huaweis are fine.
Was working with older versions, certianly V....277
Old 09-09-2018, 22:11   #21 (permalink)
Member: 2094323
https://ibb.co/d4AcaU
Meant to add this to my post above.
Can't embed images for some reason.
Old 09-10-2018, 09:51   #22 (permalink)
Member: 2023196
Thanks Meter: 1,398
Originally Posted by Sparkrite View Post
Hi,
Please do this:
1. Restart HCU software.
2. Login with your account on software.
3. Right click on memo area make sure "enable debug logging" has a check mark.
4. Try to Detect your device, after error do rest of the steps
5. Right click on memo area and save "debug log file".
6. Send that file to me, please. can send it via private message to this topic link.
Old 09-10-2018, 16:59   #23 (permalink)
Member: 2094323
Originally Posted by Namelocked View Post
Please do this:
Done,
Thank you.
Look forward to your reply.
Old 09-10-2018, 17:54   #24 (permalink)
Member: 169896
Thanks Meter: 238
Any update on P20 Imei repair @Namelocked ?
Sent from my SM-G965W using Tapatalk
Old 09-11-2018, 08:48   #25 (permalink)
Member: 2023196
Thanks Meter: 1,398
No, it is not supported as of yet.
Old 09-11-2018, 08:56   #26 (permalink)
Member: 2023196
Thanks Meter: 1,398
Done,
Thank you.
Your phone is possibly in charge only mode... Also your phone version is currently not supported. You possibly need to dongrade it via fastboot and then it may work.
Old 09-11-2018, 16:48   #27 (permalink)
Member: 2094323
Strange one, the phone is in the correct config. with debugging enabled.
It did work before, albeit in build 133, phone rom, that is.
It was actually me that uploaded the files to you, so you could support it.
Anything I can do to help?
Cheers.
Old 09-11-2018, 16:56   #28 (permalink)
Member: 2023196
Thanks Meter: 1,398
Cheers.
For now only as mentioned downgrade may help it.
Old 01-17-2019, 02:56   #29 (permalink)
Member: 1858778
Thanks Meter: 23
Please add FRP code calculator only with IMEI! Thanks
Old 01-18-2019, 03:59   #30 (permalink)
Member: 349443
when Honor Note 10 will be added? Need change the region
Page generated in 0.31686 seconds with 7 queries
