10-09-2019, 09:17 | #1 (permalink) |
No Life Poster Join Date: Jan 2005 Location: ALGERIA Age: 53
Member: 112185 Status: Offline Sonork: 100.1612613 Thanks Meter: 163 | help dead honor 8x max detected only qualcom usb hs qloader 9008 port. Code: 07/10/2019 14:49:12 Starting to write device in FASTBOOT mode... File size: 4*007*416*452 bytes AMSS version: ARE-L22HN 8.2.0.153(C900) Looking for a device in fastboot mode Device found: 0000000000000000 Getting IMEI... Getting build number... Getting model ... Getting battery state... Getting backdoor info... Getting lock state info... Getting lock boot info... SN:0000000000000000 IMEI:862565041444604 MEID:A000009B08DFDB Build number: Error: /preas/xxx not found in /product/hw_oem/ARE-AL00/par Battery state: 4106mv Process identifier:19301646 Erasing ver .. . Cannot get FBlock info from device Cannot get HW FBlock info from device Writing RPM partition RPM partition UPDATE ...OK Writing PMIC partition PMIC partition UPDATE ...OK Writing TZ partition TZ partition UPDATE ...OK Writing HYP partition HYP partition UPDATE ...OK Writing XBL partition XBL partition UPDATE ...OK Writing APDP partition APDP partition UPDATE ...OK Writing MSADP partition MSADP partition UPDATE ...OK Writing CMNLIB partition CMNLIB partition UPDATE ...OK Writing KEYMASTER partition KEYMASTER partition UPDATE ...OK Writing CMNLIB64 partition CMNLIB64 partition UPDATE ...OK Writing DEVCFG partition DEVCFG partition UPDATE ...OK Writing LKSECAPP partition LKSECAPP partition UPDATE ...OK Writing ABL partition ABL partition UPDATE ...OK Writing DSP partition DSP partition UPDATE ...OK Writing MODEM partition MODEM partition UPDATE ...OK Writing BLUETOOTH partition BLUETOOTH partition UPDATE ...OK Writing KERNEL partition KERNEL partition UPDATE ...OK Writing RAMDISK partition RAMDISK partition UPDATE ...OK Writing RECOVERY_RAMDISK partition RECOVERY_RAMDISK partition UPDATE ...OK Writing RECOVERY_VENDOR partition RECOVERY_VENDOR partition UPDATE ...OK Erasing SYSTEM partition Partition SYSTEM erased Writing SYSTEM partition sending sparse file 536320812 bytes Waiting for answer... send sparse file OK sending sparse file 514413336 bytes Waiting for answer... send sparse file OK sending sparse file 535671040 bytes Waiting for answer... send sparse file OK sending sparse file 493725064 bytes Waiting for answer... send sparse file OK SYSTEM partition UPDATE ...OK Erasing CACHE partition Partition CACHE erased Writing CACHE partition CACHE partition UPDATE ...OK Erasing ODM partition Partition ODM erased Writing ODM partition ODM partition UPDATE ...OK Writing PREAS partition sending sparse file 529503580 bytes Waiting for answer... send sparse file ERROR PREAS partition UPDATE :FAIL No such partition. Writing PREAVS partition PREAVS partition UPDATE :FAIL No such partition. Erasing USERDATA partition Partition USERDATA erased Writing USERDATA partition USERDATA partition UPDATE ...OK Writing ERECOVERY_KERNEL partition ERECOVERY_KERNEL partition UPDATE ...OK Writing ERECOVERY_RAMDISK partition ERECOVERY_RAMDISK partition UPDATE ...OK Writing ERECOVERY_VENDOR partition ERECOVERY_VENDOR partition UPDATE ...OK Software written 07/10/2019 14:52:50 Writing device finished - INCOMPLETE now not accept board software! Code: No devices detected in force upgrade mode Device detected: COM76: Qualcomm HS-USB QDLoader 9008 (COM76) 09/10/2019 09:15:59 Starting to write device in UPGRADE mode... Cannot detect device, try again 09/10/2019 09:16:12 Writing device finished with ERROR |
10-10-2019, 12:15 | #3 (permalink) |
Member: 112185 Status: Offline Sonork: 100.1612613 Thanks Meter: 163 | phone repaired boot ok and updated with xml file sucessfully many thanks to DIMITRY !! |
The Following User Says Thank You to recan21 For This Useful Post: |
11-04-2019, 07:47 | #9 (permalink) | |
No Life Poster Join Date: Nov 2017 Location: Russian
Member: 2778414 Status: Offline Thanks Meter: 342 | Quote:
************************************************** ********** Attention ALL !! . If you want to rebrand on this phone it doesn’t work out There are 636 and 660 SNAPs. These are different boards. | |
