Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > DC Unlocker
Old 12-14-2017, 17:15   #1 (permalink)
Crazy Poster
Member: 1946869
Sonork: tonyx
Thanks Meter: 7
help hcu client Access denied (for using protocol monitoring software)
Before detection connect cable to usb and enable Manufacture mode !
Qualcomm and HiSilicon: *#*#2846579#*#*
MTK: *#*#14789632#*#*
Windows: ##2846579#
ProjectMenu
1.Background setting
2.USB ports setting
Select Manufacture mode
2017.12.14 11:39:22.482 Checking account blackphone_06...
2017-12-14 11:39:22.490 Connecting to server...
2017-12-14 11:39:25.211 Connected!
2017.12.14 11:39:56.392 Checking account blackphone_06...
2017-12-14 11:39:56.401 Connecting to server...
2017-12-14 11:39:57.830 Connected!
2017.12.14 11:43:19.791 Checking account blackphone_06...
2017-12-14 11:43:19.799 Connecting to server...
2017-12-14 11:43:22.220 Connected!
Old 12-15-2017, 09:04   #2 (permalink)
Member: 2023196
Thanks Meter: 1,249
And your username is...?
Old 12-15-2017, 14:31   #3 (permalink)
Crazy Poster
Member: 1946869
Sonork: tonyx
Thanks Meter: 7
[QUOTE=Namelocked;12844190]And your username is...?
hi bro blackphone_06
Old 12-15-2017, 16:10   #4 (permalink)
Shensohau's Avatar
Member: 1377783
Sonork: 100.1611724
Thanks Meter: 2,785
Please uninstall al software that you use for share usb ports, wincap etc... then restart pc and try again...
Best Regards
Shensohau
The Following User Says Thank You to Shensohau For This Useful Post:
Old 12-15-2017, 16:48   #5 (permalink)
Member: 2023196
Thanks Meter: 1,249
[QUOTE=tonyramire;12844844]
Your computer runs usb activity scanning/sharing service, therefore you got blocked. You must remove such service/software from computer before using DC-unlocker otherwise you will get blocked again.
Block now removed. If you do not know what service/software on your machine causes this then can suggest only to use dc-unlocker from another pc. Note: receiving multiple blocks for same reason may end up with a permanent block.
Old 12-26-2017, 17:24   #6 (permalink)
Crazy Poster
Member: 1946869
Sonork: tonyx
Thanks Meter: 7
[QUOTE=Namelocked;12845112]
That's why the problem is coming to me now after 1 year of use
Old 12-26-2017, 18:20   #7 (permalink)
Crazy Poster
Member: 1946869
Sonork: tonyx
Thanks Meter: 7
Windows: ##2846579#
ProjectMenu
2.USB ports setting
2017.12.26 12:49:47.997 Checking account blackphone_06...
2017-12-26 12:49:48.008 Connecting to server...
2017-12-26 12:49:49.685 Connected!
Old 12-28-2017, 16:16   #8 (permalink)
Shensohau's Avatar
Member: 1377783
Sonork: 100.1611724
Thanks Meter: 2,785
Hi, please uninstall all usb sharing ports software, wincap etc, all those will block your account, if you will continue use it your account will be blocked permantely please avoid it... uninstall them or use licence on a clean pc without monitoring software
Best Regards
Shensohau
Old 12-28-2017, 19:32   #9 (permalink)
Crazy Poster
Member: 1946869
Sonork: tonyx
Thanks Meter: 7
Best Regards
Shensohau
I use it on another clean PC and it throws me the same message they can not reset my account
Old 01-01-2018, 13:51   #10 (permalink)
Shensohau's Avatar
Member: 1377783
Sonork: 100.1611724
Thanks Meter: 2,785
Hi, it wil be unblocked on january, 2
Best Regards
Shensohau
Old 01-02-2018, 09:56   #11 (permalink)
Member: 2023196
Thanks Meter: 1,249
Block now removed again, you should be able to log in.
Old 02-22-2019, 20:52   #12 (permalink)
Member: 1255356
Sonork: 100.1607364
Thanks Meter: 129
hcu client server access denied (prohibited process detected)
Old 02-22-2019, 20:53   #13 (permalink)
Member: 1255356
Sonork: 100.1607364
Thanks Meter: 129
dc unlock now saying account is blocked
Old 02-25-2019, 10:40   #14 (permalink)
Member: 2023196
Thanks Meter: 1,249
Yes, if your account is blocked that's what it says.
Old 09-28-2019, 16:57   #15 (permalink)
Member: 1895339
Sonork: 12458976
Hi.
username: hsynalvr
Access denied ( for using protocol monitoring software )
please remove bloced
Page generated in 0.40577 seconds with 7 queries
