Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > DC Unlocker
Old 09-30-2019, 15:00   #16 (permalink)
Member: 2023196
Thanks Meter: 1,249
Originally Posted by cakal263 View Post
Hi.
username: hsynalvr
Access denied ( for using protocol monitoring software )
please remove bloced
You got blocked again for same reason. Your computer runs usb activity scanning/sharing service, therefore you got blocked. You must remove such service/software from computer before using DC-unlocker otherwise you will get blocked again.
Block now removed - i won't be able to remove it again. If you do not know what service/software on your machine causes this then can only suggest to use dc-unlocker from another pc. Note: receiving multiple blocks for same reason may end up with a permanent block.
Old 01-02-2020, 16:31   #17 (permalink)
Member: 2784632
hi my hcu account blocked and i'm not install any usb software share
2020-01-02 07:28:46.855 Checking account hema1133...
2020-01-02 07:28:46.860 Connecting to server...
2020-01-02 07:28:49.437 Connected!
Access denied (for using protocol monitoring software)
Old 01-02-2020, 19:57   #18 (permalink)
Punto-Móvil's Avatar
Member: 1147852
Sonork: 1602463
Thanks Meter: 278
Hi there ,
am having the same problem which is caused by flexihub .
we use it to get samsung phones frp unlocked remotely. so software is necessary for our work.
first run i forgot to uninstall it but second run i uninstall it restarted pc and rerun software there i got access denied.
i ve done this process many times before and never got blocked.
I need my dongle to be unblocked .should i post serial dongle here or send it private.
Best Regards,
PuntoMovil
Old 01-03-2020, 16:59   #19 (permalink)
Member: 2023196
Thanks Meter: 1,249
Should be working now.
Old 01-03-2020, 17:00   #20 (permalink)
Member: 2023196
Thanks Meter: 1,249
Originally Posted by Punto-Móvil View Post
Hi there ,
Best Regards,
PuntoMovil
Will be good either way.
Old 01-04-2020, 10:03   #21 (permalink)
Member: 2784632
it's work ,thanks bro
Old 01-06-2020, 12:48   #22 (permalink)
Member: 1147852
Sonork: 1602463
Thanks Meter: 278
Hi there
My dongle is still blocked now almost 4 days.
I ve sent you serial in private and now i post it here.
please unblock it .
thanks in advance.
Punto-Movil
2020-01-06 12:44:03.891 Checking account 0D9FAFFE...
2020-01-06 12:44:16.744 Connecting to server...
2020-01-06 12:44:16.997 Connected!
Old 01-06-2020, 16:40   #23 (permalink)
Member: 2023196
Thanks Meter: 1,249
Hi there
please unblock it .
thanks in advance.
Punto-Movil
Block now removed. If you do not know what service/software on your machine causes this then can only suggest to use dc-unlocker from another pc. Note: receiving multiple blocks for same reason may end up with a permanent block.
Page generated in 0.37501 seconds with 7 queries
