Help to recover p10 hi team,, i was trying to downgrade vtr-29, and i bricked the phone, i found a guide and xda using p10 revive, but icant acces upgrade mode, also im not able to install recovery allways getting error remote: image verification error |
Then you should try to use testpoint/oeminfo solution from DC-phoenix guide. |
i did tp method, tp,wite oem info but still getting error Looking for a device in upgrade mode No devices detected in upgrade mode Device found: YLM7N17412001380 17/9/2019 22:16:36 Starting to write device in FASTBOOT mode... File size: 4*631*411*088 bytes Current version(CURVER): VTR_C900_EMUI8.0_xloader Looking for a device in fastboot mode Device found: YLM7N17412001380 Getting IMEI... Getting build number... Getting model ... Getting battery state... Getting backdoor info... Getting lock state info... Getting lock boot info... SN:YLM7N17412001380 IMEI:862790039009264 IMEI1:862790039010965 MEID:86279003900926 Build number: :VTR-L29C605B123 Model: VTR-L29 Battery state: 0 OEM lock state info: FB LockState: UNLOCKED USER LockState: LOCKED OEM get bootinfo: unlocked Process identifier:18695634 Erasing ver .. . Writing XLOADER partition XLOADER partition UPDATE ...OK Writing FW_LPM3 partition FW_LPM3 partition UPDATE ...OK Writing FASTBOOT partition FASTBOOT partition UPDATE ...OK Writing VECTOR partition VECTOR partition UPDATE ...OK Writing VBMETA partition VBMETA partition UPDATE :FAIL partition length get error Cannot get FBlock info from device Trying to unlock device... Signing process may take few minutes Trying to get data from server Waiting in queue for signing service. Expected time 5 second(s) to get data from server Trying to get data from server Writing VBMETA partition VBMETA partition UPDATE :FAIL partition length get error Writing MODEMNVM_UPDATE partition MODEMNVM_UPDATE partition UPDATE ...OK Writing TEEOS partition TEEOS partition UPDATE ...OK Writing TRUSTFIRMWARE partition TRUSTFIRMWARE partition UPDATE ...OK Writing SENSORHUB partition SENSORHUB partition UPDATE ...OK Writing FW_HIFI partition FW_HIFI partition UPDATE ...OK Writing DTS partition DTS partition UPDATE ...OK Writing KERNEL partition KERNEL partition UPDATE :FAIL partition length get error Writing RECOVERY_RAMDISK partition RECOVERY_RAMDISK partition UPDATE :FAIL partition length get error Writing RECOVERY_VENDOR partition RECOVERY_VENDOR partition UPDATE :FAIL partition length get error Writing RECOVERY_VBMETA partition RECOVERY_VBMETA partition UPDATE :FAIL partition length get error Writing ERECOVERY_KERNEL partition ERECOVERY_KERNEL partition UPDATE :FAIL partition length get error Writing ERECOVERY_RAMDISK partition ERECOVERY_RAMDISK partition UPDATE :FAIL partition length get error Writing ERECOVERY_VENDOR partition ERECOVERY_VENDOR partition UPDATE :FAIL partition length get error Writing ERECOVERY_VBMETA partition ERECOVERY_VBMETA partition UPDATE :FAIL partition length get error Writing RAMDISK partition RAMDISK partition UPDATE :FAIL partition length get error Erasing CACHE partition Partition CACHE erased Writing CACHE partition CACHE partition UPDATE ...OK Writing SYSTEM partition sending sparse file 399459508 bytes Waiting for answer... send sparse file OK sending sparse file 469649892 bytes Waiting for answer... send sparse file OK sending sparse file 471406812 bytes Waiting for answer... send sparse file OK sending sparse file 457677456 bytes Waiting for answer... send sparse file OK sending sparse file 471235384 bytes Waiting for answer... send sparse file OK sending sparse file 373198644 bytes Waiting for answer... send sparse file OK sending sparse file 452594296 bytes Waiting for answer... send sparse file OK sending sparse file 294533536 bytes Waiting for answer... send sparse file OK SYSTEM partition UPDATE ...OK Erasing CUST partition Partition CUST erased Writing CUST partition CUST partition UPDATE ...OK Writing ISP_FIRMWARE partition ISP_FIRMWARE partition UPDATE ...OK Writing MODEM_FW partition MODEM_FW partition UPDATE ...OK Writing HISEE_IMG partition HISEE_IMG partition UPDATE ...OK Writing HISEE_FS partition HISEE_FS partition UPDATE ...OK Writing VERSION partition VERSION partition UPDATE ...OK Writing ODM partition ODM partition UPDATE :FAIL partition length get error Erasing USERDATA partition Partition USERDATA erased Writing USERDATA partition USERDATA partition UPDATE ...OK Software written 17/9/2019 22:21:05 Writing device finished - INCOMPLETE |
So how about you put it in upgrade mode manually and press continue/retry? |
i tried but allways get an erro update failed even before flashing process start |
Means you are putting in this mode incorrectly, phone probably is looking for files in sd card, you must put it to this mode when phone is connected to cable. |
what is your problem ? attach your log |
Phone screen is black but can go into fastboot and USB com 1.0 Testpoint mode also. I've tried different firmware Here is the log: Standard update Not Reboot NOT cheked Update Verlist to server on file load checked Try Rescue Recovery NOT checked Bypass version check NOT checked Old slow algo checked Looking for a device in upgrade mode No devices detected in upgrade mode Device found: 0123456789ABCDEF 19-May-20 02:50:19 Starting to write device in FASTBOOT mode... Looking for a device in fastboot mode Device found: 0123456789ABCDEF Getting IMEI... Getting build number... Getting model ... Getting battery state... Getting backdoor info... Getting lock state info... Getting lock boot info... IMEI:862790039009264 IMEI1:862790039010965 MEID:86279003900926 Build number: :VTR-L29C605B123 Model: VTR-L29 Vendor/Country: hw/la Battery state: 0 OEM lock state info: FB LockState: UNLOCKED USER LockState: LOCKED OEM get bootinfo: unlocked Process identifier:24537476 Erasing ver .. . Extracting partition XLOADER... Writing XLOADER partition XLOADER partition update :FAIL image xloader1 verification error Getting lock state info... Writing XLOADER partition XLOADER partition update :FAIL image xloader1 verification error Extracting partition FW_LPM3... Writing FW_LPM3 partition FW_LPM3 partition update :FAIL image verification error Extracting partition FASTBOOT... Writing FASTBOOT partition FASTBOOT partition update :FAIL image verification error Extracting partition VECTOR... Writing VECTOR partition VECTOR partition update :FAIL image verification error Extracting partition MODEMNVM_UPDATE... Writing MODEMNVM_UPDATE partition MODEMNVM_UPDATE partition update ...OK Extracting partition TEEOS... Writing TEEOS partition TEEOS partition update :FAIL image verification error Extracting partition TRUSTFIRMWARE... Writing TRUSTFIRMWARE partition TRUSTFIRMWARE partition update :FAIL image verification error Extracting partition SENSORHUB... Writing SENSORHUB partition SENSORHUB partition update :FAIL image verification error Extracting partition FW_HIFI... Writing FW_HIFI partition FW_HIFI partition update :FAIL image verification error Extracting partition BOOT... Writing BOOT partition BOOT partition update ...OK Extracting partition RECOVERY... Writing RECOVERY partition RECOVERY partition update ...OK Extracting partition RECOVERY2... Writing RECOVERY2 partition RECOVERY2 partition update ...OK Extracting partition DTS... Writing DTS partition DTS partition update ...OK Extracting partition CACHE... Erasing CACHE partition Partition CACHE erased Writing CACHE partition CACHE partition update ...OK Extracting partition SYSTEM... Writing SYSTEM partition sending sparse file 391220988 bytes Waiting for answer... send sparse file OK sending sparse file 393359696 bytes Waiting for answer... send sparse file OK sending sparse file 443303372 bytes Waiting for answer... send sparse file OK sending sparse file 471333956 bytes Waiting for answer... send sparse file OK sending sparse file 467468628 bytes Waiting for answer... send sparse file OK sending sparse file 465541764 bytes Waiting for answer... send sparse file OK sending sparse file 450294888 bytes Waiting for answer... send sparse file OK sending sparse file 440698032 bytes Waiting for answer... send sparse file OK sending sparse file 213413732 bytes Waiting for answer... send sparse file OK SYSTEM partition update ...OK Extracting partition ISP_FIRMWARE... Writing ISP_FIRMWARE partition ISP_FIRMWARE partition update :FAIL image verification error Extracting partition MODEM_FW... Writing MODEM_FW partition MODEM_FW partition update :FAIL image verification error Extracting partition HISEE_IMG... Writing HISEE_IMG partition HISEE_IMG partition update ...OK Extracting partition HISEE_FS... Writing HISEE_FS partition HISEE_FS partition update ...OK Extracting partition USERDATA... Erasing USERDATA partition Partition USERDATA erased Writing USERDATA partition USERDATA partition update ...OK Software written 19-May-20 03:09:29 Writing device finished - INCOMPLETE Waiting for fastboot device... USB Device REMOVAL Type: @oem179.inf,%singlebootloaderinterface%;Android Bootloader Interface VidPid: VID_18D1&PID_D00D Instance id: 0123456789ABCDEF No devices detected in fastboot mode |
Make sure rescue recovery and bypass version options are checked and flash it from dc-phoenix v131. And when you pasting logs use special options created for that so it won't take whole page. |
