12-28-2019, 08:27 | #1 (permalink) |
Freak Poster Join Date: Apr 2016 Location: azaz
Member: 2560889 Status: Offline Thanks Meter: 106 | VOG-L29 error flashing when flashing by DC Phoenix it reach 30% then DC say error writing firmware. now phone just enter fastboot, tried to enter upgrade mode but in vain. how to solve please help phone info: https://drive.google.com/file/d/164w...ApSnh7YGi/view |
01-07-2020, 17:05 | #4 (permalink) |
Junior Member Join Date: Dec 2015
Member: 2500590 Status: Offline Thanks Meter: 1 | try dload firmware link sent to you check your inbox Instructions This is the requirements 1- Upgrade with USB-OTG An OTG cable A USB drive (8GB at least) Formatted as NTFS or ExFat Also you can use an USB drive + USB C adapter Open the Zip and extract the dload folder on the pendrive - Turn off the P30 Pro - Connect the pendrive with the OTG cable - Now press the three buttons at the same time. - Volume + - Volume - - Power button. (The p30pro will light up and vibrate, keep the buttons pressed) Only when you see the blank screen and EMUI appears will you release the buttons. The flashing will start and lasts about 2 minutes. After flashing the P30 Pro will restart automatically Last edited by ozoozo; 01-07-2020 at 17:11. |
01-09-2020, 20:45 | #7 (permalink) |
Junior Member Join Date: Nov 2015
Member: 2485548 Status: Offline Thanks Meter: 0 | p30 pro dead after flash with DC Phoenix i have vog-l29 working 100% and want to update android 10. when flashing by DC Phoenix it reach 30% then DC say error writing firmware. help me please |
01-14-2020, 14:27 | #10 (permalink) |
Member: 2500590 Status: Offline Thanks Meter: 1 | try dload firmware link https://androidhost.ru/2AV6 Instructions This is the requirements 1- Upgrade with USB-OTG An OTG cable A USB drive (8GB at least) Formatted as NTFS or ExFat Also you can use an USB drive + USB C adapter Open the Zip and extract the dload folder on the pendrive - Turn off the P30 Pro - Connect the pendrive with the OTG cable - Now press the three buttons at the same time. - Volume + - Volume - - Power button. (The p30pro will light up and vibrate, keep the buttons pressed) Only when you see the blank screen and EMUI appears will you release the buttons. The flashing will start and lasts about 2 minutes. After flashing the P30 Pro will restart automatically |
01-14-2020, 14:29 | #11 (permalink) |
