01-14-2019, 06:17 | #1 (permalink) |
Crazy Poster Join Date: Jun 2016 Location: Sudan
Member: 2583933 Status: Offline Thanks Meter: 19 | HUAWEI MATE 9 MHA-AL00 bricked i have HUAWEI MATE 9 MHA-AL00 i got this device brciked in HUAWEI USB COM MODE someone flash it by board fw then i debricked the device by write Kirin960_T2_A7.0_V3 beacuse main TP board fw seems not compatble with device BL VER MHA-AL00A_HLMHAAL00AM00A064_Board Software_inc_testpoint.dgtks not work any way debricked by this Kirin960_T2_A7.0_V3 Device detected: COM77: HUAWEI USB COM 1.0 (COM77) BOOTLOADER File to update: Kirin960_T2_A7.0_V3 OEM File to update: MHA-L29 1/14/2019 7:04:26 AM Starting to write device... Writing bootloader... Writing Kirin960_T2_A7.0_V3_3.dtwork... Writing Kirin960_T2_A7.0_V3_4.dtwork... Writing Kirin960_T2_A7.0_V3_5.dtwork... Waiting for fastboot device... Device found: 0123456789ABCDEF Looking for a device in fastboot mode Device found: 0123456789ABCDEF Battery state: 4312mv Writing OEMINFO partition OEMINFO partition UPDATE ...OK Software written 1/14/2019 7:05:05 AM Writing device finished OK after this if i tick reboot button or just unplug usb cable ANDROID reboor reason coldboot NA check-boot-mode try to flash many files all logs is same MHA-AL00 , L29 , L09 , TL00 4 board fw files also HLMHAAL00AM00A070 , 71 , 69 , 74 all logs is same FAIL image verification error C:\Users\my\Downloads\MHA-TL00A_C01B213_Firmware_China_Nonspecific_Android7. 0_EMUI5.0.APP Looking for a device in upgrade mode No devices detected in upgrade mode Device found: 0123456789ABCDEF 1/14/2019 6:55:01 AM Starting to write device in FASTBOOT mode... Looking for a device in fastboot mode Device found: 0123456789ABCDEF Battery state: 5391mv Extracting partition XLOADER... Writing XLOADER partition XLOADER partition UPDATE :FAIL image xloader1 verification error Cannot get FBlock info from device Trying to unlock device... Writing XLOADER partition XLOADER partition UPDATE :FAIL image xloader1 verification error Extracting partition FW_LPM3... Writing FW_LPM3 partition FW_LPM3 partition UPDATE :FAIL image verification error Extracting partition FASTBOOT... Writing FASTBOOT partition FASTBOOT partition UPDATE :FAIL image verification error Extracting partition VECTOR... Writing VECTOR partition VECTOR partition UPDATE :FAIL image verification error Extracting partition MODEMNVM_UPDATE... Writing MODEMNVM_UPDATE partition MODEMNVM_UPDATE partition UPDATE ...OK Extracting partition TEEOS... Writing TEEOS partition TEEOS partition UPDATE :FAIL image verification error Extracting partition TRUSTFIRMWARE... Writing TRUSTFIRMWARE partition TRUSTFIRMWARE partition UPDATE :FAIL image verification error Extracting partition SENSORHUB... Writing SENSORHUB partition SENSORHUB partition UPDATE :FAIL image verification error Extracting partition FW_HIFI... Writing FW_HIFI partition FW_HIFI partition UPDATE :FAIL image verification error Extracting partition BOOT... Writing BOOT partition BOOT partition UPDATE ...OK Extracting partition RECOVERY... Writing RECOVERY partition RECOVERY partition UPDATE ...OK Extracting partition RECOVERY2... Writing RECOVERY2 partition RECOVERY2 partition UPDATE ...OK Extracting partition DTS... Writing DTS partition DTS partition UPDATE ...OK Extracting partition CACHE... Erasing CACHE partition Partition CACHE erased Writing CACHE partition CACHE partition UPDATE ...OK Extracting partition SYSTEM... Writing SYSTEM partition sending sparse file 469762048 bytes send sparse file OK sending sparse file 469762048 bytes send sparse file OK sending sparse file 469762048 bytes send sparse file OK sending sparse file 469762048 bytes send sparse file OK sending sparse file 469762048 bytes send sparse file OK sending sparse file 349806240 bytes send sparse file OK SYSTEM partition UPDATE ...OK Extracting partition ISP_FIRMWARE... Writing ISP_FIRMWARE partition ISP_FIRMWARE partition UPDATE :FAIL image verification error Extracting partition MODEM_FW... Writing MODEM_FW partition MODEM_FW partition UPDATE :FAIL image verification error Extracting partition HISEE_IMG... Writing HISEE_IMG partition HISEE_IMG partition UPDATE ...OK Extracting partition HISEE_FS... Writing HISEE_FS partition HISEE_FS partition UPDATE ...OK Extracting partition USERDATA... Erasing USERDATA partition Partition USERDATA erased Writing USERDATA partition USERDATA partition UPDATE ...OK Software written 1/14/2019 7:02:29 AM Writing device finished - INCOMPLETE Waiting for fastboot device... No devices detected in fastboot mode Cannot update device in upgrade mode //***************************************** device go to HUAWEI USB COM 1.0 then i repaeat debrick operation again Device detected: COM77: HUAWEI USB COM 1.0 (COM77) BOOTLOADER File to update: Kirin960_T2_A7.0_V3 OEM File to update: MHA-L29 1/14/2019 7:04:26 AM Starting to write device... Writing bootloader... Writing Kirin960_T2_A7.0_V3_3.dtwork... Writing Kirin960_T2_A7.0_V3_4.dtwork... Writing Kirin960_T2_A7.0_V3_5.dtwork... Waiting for fastboot device... Device found: 0123456789ABCDEF Looking for a device in fastboot mode Device found: 0123456789ABCDEF Battery state: 4312mv Writing OEMINFO partition OEMINFO partition UPDATE ...OK Software written 1/14/2019 7:05:05 AM Writing device finished OK after this if i tick reboot button or just unplug usb cable //***************************************** device go to HUAWEI USB COM 1.0 |
01-14-2019, 11:49 | #2 (permalink) |
Product Supporter Join Date: Sep 2013 Location: Lithuania, Kaunas
Member: 2023196 Status: Offline Thanks Meter: 1,891 | What you need to do after flashing loader+ oeminfo is to flash full stock rom that matches oeminfo repaired details. If that does not help and phone remains alwaus in com 1 then only main board replacement can help you. |
The Following User Says Thank You to Namelocked For This Useful Post: |
01-14-2019, 12:00 | #3 (permalink) | |
Member: 2583933 Status: Offline Thanks Meter: 19 | Quote:
i think replacement is right choice thanks for support | |
The Following User Says Thank You to jidophone For This Useful Post: |
01-21-2019, 19:59 | #4 (permalink) |
Junior Member Join Date: Aug 2007 Location: tunisie
Member: 566943 Status: Offline Thanks Meter: 11 | Solution to umbrick your phone is: - after you flash bootloader Kirin960_T2_A7.0_V3 - you have to flash HLMHAAL00AM00A073_Board Software_general_7.0.0_r1_EMUI5.0_05021YVS - in Dc phoenix select update_nv_rback.xml and flash it in advanced mode reboot manual to update mode with usb cable in flash the last stock firmware like 8.0.0.380 or 381+++ that's it |
The Following 9 Users Say Thank You to issam_11_issam For This Useful Post: |
02-25-2019, 21:32 | #5 (permalink) | |
Insane Poster Join Date: Oct 2014
Member: 2268606 Status: Offline Thanks Meter: 5 | Quote:
now the IMEI is 000000000000 do you know how to fix it? i tried hcu but it's not supported! | |
02-26-2019, 02:50 | #6 (permalink) | |
Junior Member Join Date: Feb 2019
Member: 2893014 Status: Offline Thanks Meter: 1 | Quote:
my IMEI too is 000000000 and HCU NO HAVE SUPORT ....HOW FIX IMEI ?????????????????????????????????????????????????? Last edited by Namelocked; 03-12-2019 at 14:13. | |
03-09-2019, 16:40 | #7 (permalink) | |
No Life Poster Join Date: Nov 2017 Location: Russian
Member: 2778414 Status: Offline Thanks Meter: 342 | Quote:
- you have to flash HLMHAAL00AM00A073_Board Software_general_7.0.0_r1_EMUI5.0_05021YVS - in Dc phoenix select update_nv_rback.xml and flash it in advanced mode 2. Fix Imei SN wifi bt and with HCU 3.Direct unlock / read bootloader 4. reboot manual to update mode with usb cable in flash the last stock firmware like 8.0.0.380 or 381+++ | |
The Following 3 Users Say Thank You to solgeo For This Useful Post: |
03-09-2019, 17:44 | #8 (permalink) | |
However the PC can detect it 'and the Adapter drivers shows up in device manager' but HCU cannot detect the phone even though drivers are installed. can you please tell us if there is something missing? | |
03-17-2019, 14:36 | #9 (permalink) |
Junior Member Join Date: Apr 2017
Member: 2704336 Status: Offline Thanks Meter: 0 | Hi Can u link me the files needed plz cant seem to find anywhere or maybe i just don't understand, device current status is i am able to get into upgrade mode but nothing seems be be flashing it says this when read in fastboot mode in DC-Unlocker (without * of course) Found Phone : MHA-L29 Model : Huawei phone in fastboot mode IMEI : ***************** Serial NR. : AHK7N17********* Firmware : MHA-L29C432B186 plz help |
07-15-2019, 15:00 | #12 (permalink) | ||
No Life Poster Join Date: May 2006 Location: Sudan
Member: 281857 Status: Offline Thanks Meter: 214 | Quote:
07-25-2019, 18:21 | #13 (permalink) | |||
Member: 281857 Status: Offline Thanks Meter: 214 | how to fix this need what mean of - in Dc phoenix select update_nv_rback.xml and flash it in advanced mode Quote:
07-25-2019, 20:11 | #14 (permalink) | |
08-19-2019, 12:59 | #15 (permalink) |
Junior Member Join Date: Nov 2016
Member: 2644171 Status: Offline Thanks Meter: 4 | need help what is the solution my MHA-AL00 is totally dead after failed to flash xloader in firmware . after update oem info the phone boot to fastboot mode but not accept any firmware and board soft . i tried the montioned solution but wont flash in in force update mode ( huawei usb 1.0 ) |
The Following 2 Users Say Thank You to evanboorn7 For This Useful Post: |
