12-30-2017, 13:43 | #1 (permalink) |
Junior Member Join Date: Jun 2014 Location: jordan
Member: 2213126 Status: Offline Thanks Meter: 22 | i nead to fix this problem Model : Huawei AuthVer 4 modem (New) IMEI : 86469503319ZZZZ Serial NR. : D2LDW17805004993 Firmware : 21.316.01.00.1029 Dashboard version : WEBUI_17.100.13.02.1029_MRE5 Web UI version : WEBUI_17.100.13.02.1029_MRE5 SIM Lock status : Locked (Card Lock) Wrong codes entered : 0 (unlock attempts left : 10) ================================================== ================= Unlocking, please wait ... Access denied (for dongle sharing) Error code 374 unlock failed ! |
12-31-2017, 13:25 | #2 (permalink) |
No Life Poster Join Date: Aug 2010 Location: Inside Logic Age: 37
Member: 1377783 Status: Offline Sonork: 100.1611724 Thanks Meter: 3,335 | Hi, please remove all usb sharing ports software... uninstall them restart pc and try gain, if you continuosly insist on that dongle will be blocked under advertise.... Best Regards Shensohau |
01-02-2018, 09:51 | #3 (permalink) | |
Product Supporter Join Date: Sep 2013 Location: Lithuania, Kaunas
Member: 2023196 Status: Offline Thanks Meter: 1,891 | Quote:
01-04-2018, 11:33 | #5 (permalink) |
Member: 2023196 Status: Offline Thanks Meter: 1,891 | I can't solve it without knowing your username or dongle id which you never told i just let you know that you won't be able to unlock your modem that you tried to unlock regardless. |
01-04-2018, 21:11 | #6 (permalink) | |
Member: 2213126 Status: Offline Thanks Meter: 22 | Quote:
This is the dongle id https://ibb.co/ewfY7G | |
01-05-2018, 09:44 | #7 (permalink) | |
Member: 2023196 Status: Offline Thanks Meter: 1,891 | Quote: Block now removed. If you do not know what service/software on your machine causes this then can suggest only to use dc-unlocker from another pc. Note: receiving multiple blocks for same reason may end up with a permanent block. | |
