Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > DC Unlocker
Old 12-30-2017, 13:43   #1 (permalink)
Member: 2213126
Thanks Meter: 21
i nead to fix this problem
Found modem : E5577Cs-321
Model : Huawei AuthVer 4 modem (New)
IMEI : 86469503319ZZZZ
Serial NR. : D2LDW17805004993
Firmware : 21.316.01.00.1029
Dashboard version : WEBUI_17.100.13.02.1029_MRE5
Web UI version : WEBUI_17.100.13.02.1029_MRE5
SIM Lock status : Locked (Card Lock)
Wrong codes entered : 0 (unlock attempts left : 10)
Unlocking, please wait ...
Access denied (for dongle sharing)
Error code 374
unlock failed !
Old 12-31-2017, 13:25   #2 (permalink)
Shensohau's Avatar
Member: 1377783
Sonork: 100.1611724
Thanks Meter: 2,737
Hi, please remove all usb sharing ports software... uninstall them restart pc and try gain, if you continuosly insist on that dongle will be blocked under advertise....
Best Regards
Shensohau
Old 01-02-2018, 09:51   #3 (permalink)
Member: 2023196
Thanks Meter: 1,219
Error code 374
unlock failed !
If firmware version begins with 2x.3xx.<...> unlock not possible, no way to flash it either, no solution, no workaround. Sorry.
Old 01-04-2018, 10:33   #4 (permalink)
Member: 2213126
Thanks Meter: 21
I do not have programs to share the usb port
The problem has not yet been resolved
Old 01-04-2018, 11:33   #5 (permalink)
Member: 2023196
Thanks Meter: 1,219
I can't solve it without knowing your username or dongle id which you never told i just let you know that you won't be able to unlock your modem that you tried to unlock regardless.
Old 01-04-2018, 21:11   #6 (permalink)
Member: 2213126
Thanks Meter: 21
This is the dongle id
https://ibb.co/ewfY7G
Old 01-05-2018, 09:44   #7 (permalink)
Member: 2023196
Thanks Meter: 1,219
Your computer runs usb activity scanning/sharing service, therefore you got blocked. You must remove such service/software from computer before using DC-unlocker otherwise you will get blocked again.
Block now removed. If you do not know what service/software on your machine causes this then can suggest only to use dc-unlocker from another pc. Note: receiving multiple blocks for same reason may end up with a permanent block.
Page generated in 0.29184 seconds with 7 queries
