Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > DC Unlocker
Old 12-26-2017, 00:20   #1 (permalink)
Member: 2781518
No Service Huawei P10 Lite
After restoring Imei and unlock SIM i can't connect to mobile provider. The phone states as "Preffered Network ; No Service". The strange thing is when i try to connect to a provider and turn on Airplaine mode i got the message "connected to network" but offcourse in airplane mode you can't do anything. Can anybode tell me how to solve this problem. By the way if i do a factory reset and put in the sim i see foor a few minutes my provider and than goes to "emergency calls only". Please i need some help to figure out how to solve this problem?
Old 12-26-2017, 10:03   #2 (permalink)
Member: 2781518
Everything is working in the telephone except data.
Old 12-26-2017, 13:00   #3 (permalink)
Shensohau's Avatar
Member: 1377783
Sonork: 100.1611724
Thanks Meter: 2,530
Hi, please check APN data for your local network provider.... thanks for your feedback...
Best Regards
Shensohau
Old 12-26-2017, 21:36   #4 (permalink)
Member: 2781518
APN setting are correct. Maybe i forgot to tell you there is a few seconds connection with my provider and than goes to "emergency calls only" i think i need nv files to fix this.
Old 12-28-2017, 05:45   #5 (permalink)
Member: 2781518
Anybody can help me with this problemen?
Old 12-28-2017, 13:11   #6 (permalink)
Shensohau's Avatar
Member: 1377783
Sonork: 100.1611724
Thanks Meter: 2,530
Hi, please try to use correct IMEI checksum on your device and please check again....
Best Regards
Shensohau
Old 12-29-2017, 19:35   #7 (permalink)
Member: 2781518
Imei is correct or do you mean something else to check?
Old 12-30-2017, 12:37   #8 (permalink)
Shensohau's Avatar
Member: 1377783
Sonork: 100.1611724
Thanks Meter: 2,530
Hi check that it is not blacklisted bro....
Best Regards
Shensohau
Old 12-30-2017, 19:56   #9 (permalink)
Member: 2781518
i already check this, not blacklisted. when i perform a factory reset i can see for about 1 minute my provider en than goes to emergency calls only. Perhaps a hardware problem than.
Old 01-01-2018, 13:55   #10 (permalink)
Shensohau's Avatar
Member: 1377783
Sonork: 100.1611724
Thanks Meter: 2,530
Hi, uhmm could be if antenna is ok, and data on device is ok, just hardware issue, try to rehot P.A area and check...
Best Regards
Shensohau
Old 01-01-2018, 22:05   #11 (permalink)
Member: 2781518
The strange thing is that if i put in *#*#6130#*#* i cannot select a baseband. Normally there is a drill down with different types of networks ( UMTS, LTE etc)
Old 01-04-2018, 22:50   #12 (permalink)
Member: 2781518
Anybody knows how to solve this??
Old 01-05-2018, 09:48   #13 (permalink)
Member: 2023196
Thanks Meter: 759
You need to flash modem nv partitions backup from fully same exact model working phone into yours.
Old 01-05-2018, 19:51   #14 (permalink)
Member: 2781518
ok, thanks. Do you know where to get these files?
Old 01-08-2018, 10:46   #15 (permalink)
Member: 2023196
Thanks Meter: 759
If NV backup versions that we have on DC-phoenix support area does not match your phone then you will have to find person that could share them with you.
Page generated in 0.37021 seconds with 7 queries
