03-03-2019, 12:57 | #1 (permalink) |
Junior Member Join Date: Feb 2019
Member: 2893014 Status: Offline Thanks Meter: 1 | try unbrick and fix IMEI HCU and IDT softwares My histore is. updated with RuHupdater v4 my mate9 for the ROM GPU turbo B377. after trying to update again my mate9 did not start more, did not enter fastboot, did not enter the recovery, nothing, nothing. the only solution was to testpoint and install the board software by IDT. but the IDT has deleted my IMEi and partitions from the modem. IMEI is 000000000000 I was able to install the rom of factory of plate MHA-L29000000073 finally the HCU corrected my IMEI using this board ROM. But other functions were not corrected and the phone did not start after fix IMEI so I had to install the Chinese STF ROM and leave it in the CHINA region for all functions to be fixed. Ok, IMEI and everything working. but .... this STF china firmware does not accept TWRP installation so I no can update my mate9 and get out of this board rom. so what method should I use to have my mate9 updated and imei working at the same time? thanks for Ante0 Oslo83 dozaga |
03-04-2019, 12:00 | #2 (permalink) |
No Life Poster Join Date: Jan 2004 Location: PAKISTAN Age: 52
Member: 48518 Status: Offline Sonork: 100.113013 Thanks Meter: 127 | having same problem with mate 9,i successfully install MHA-L29 with dc phoenix ,i use this version MHA-L29B 8.0.0.377(C432) in upgrade mode but 1st write oeminfo after write imei become 0000000000, when i try to repair imei on board firmware mobile hang and dont start. |
03-05-2019, 01:46 | #3 (permalink) | |
Member: 2893014 Status: Offline Thanks Meter: 1 | Quote:
03-06-2019, 10:08 | #4 (permalink) |
Member: 48518 Status: Offline Sonork: 100.113013 Thanks Meter: 127 | basically i have MHA-Al00 ,want to convert to L29,during convert mobile goes dead,after i try every possible solution but not succeed.Then i use IDT which make my phone alive but imei become 00000000.if u want to write twrp,then 1st read its bootloader code by hcu after writing board firmware. Last edited by xtreme; 03-06-2019 at 10:11. Reason: if u want to write twrp,then 1st read its bootloader code by hcu after writing board firmware. |
03-12-2019, 19:30 | #7 (permalink) |
Member: 48518 Status: Offline Sonork: 100.113013 Thanks Meter: 127 | At last successfully recover MHA-AL00.want to remove huawei id, 1st write latest board firmware i use this one HLMHAAL00AM00A074 then repair its imei with HCU after reboot do direct unlock and write oeminfo of MHA-L29 with dc phoenix and write firmware of MHA-L29(i use this MHA-L29B 8.0.0.377(C432) .phone power on and working. |
