04-24-2019, 08:41 | #1 (permalink) |
No Life Poster Join Date: Nov 2006 Location: *P*A*K*I*S*T*A*N
Member: 391445 Status: Offline Sonork: 100.1583575 Thanks Meter: 392 | Unable to remove screenlock WAS-LX1A Code: SN:2XJDU17408001222 IMEI:8630940xxxxxxx IMEI1:863094032xxxxxx MEID:00000000000000 Build number: :WAS-LX1AC432B186 Model: WAS-LX1A Battery state: 1800mv OEM lock state info: FB LockState: LOCKED USER LockState: LOCKED OEM get bootinfo: locked Code: Looking for a device in upgrade mode No devices detected in upgrade mode Device found: 2XJDU17408001222 4/24/2019 3:34:16 PM Starting to write device in FASTBOOT mode... Looking for a device in fastboot mode Device found: 2XJDU17408001222 Getting IMEI... Getting build number... Getting model ... Getting battery state... Getting backdoor info... Getting lock state info... Getting lock boot info... SN:2XJDU17408001222 IMEI:8630940xxxxxxxx IMEI1:86309403xxxxxxx MEID:00000000000000 Build number: :WAS-LX1AC432B186 Model: WAS-LX1A Battery state: 3703mv OEM lock state info: FB LockState: LOCKED USER LockState: LOCKED OEM get bootinfo: locked Extracting partition XLOADER... Writing XLOADER partition XLOADER partition UPDATE :FAIL Command not allowed Cannot get FBlock info from device Trying to unlock device... Writing XLOADER partition XLOADER partition UPDATE ...OK Extracting partition FW_LPM3... Writing FW_LPM3 partition FW_LPM3 partition UPDATE :FAIL flash write prim vrl failure Extracting partition FASTBOOT... Writing FASTBOOT partition FASTBOOT partition UPDATE :FAIL flash write prim vrl failure Extracting partition MODEMNVM_UPDATE... Writing MODEMNVM_UPDATE partition MODEMNVM_UPDATE partition UPDATE ...OK Extracting partition TEEOS... Writing TEEOS partition TEEOS partition UPDATE :FAIL flash write prim vrl failure Extracting partition TRUSTFIRMWARE... Writing TRUSTFIRMWARE partition TRUSTFIRMWARE partition UPDATE :FAIL flash write prim vrl failure Extracting partition SENSORHUB... Writing SENSORHUB partition SENSORHUB partition UPDATE :FAIL flash write prim vrl failure Extracting partition FW_HIFI... Writing FW_HIFI partition FW_HIFI partition UPDATE :FAIL flash write prim vrl failure Extracting partition BOOT... Writing BOOT partition BOOT partition UPDATE :FAIL flash write prim vrl failure Extracting partition RECOVERY... Writing RECOVERY partition RECOVERY partition UPDATE :FAIL flash write prim vrl failure Extracting partition RECOVERY2... Writing RECOVERY2 partition RECOVERY2 partition UPDATE :FAIL flash write prim vrl failure Extracting partition DTS... Writing DTS partition DTS partition UPDATE FAIL Fatal error: Cannot access to device Cannot access to device 4/24/2019 3:38:35 PM Writing device finished - INCOMPLETE |
04-25-2019, 10:16 | #3 (permalink) |
Registered User Join Date: Oct 2012
Member: 1822958 Status: Offline Thanks Meter: 45 | some fairly cheap tools like UAT have screen lock removal but ive never tested it, alsojust a word of warning if youre blocking out the IMEI (like IMEI:8630940xxxxxxx) you should probably block out the serial no too as you can get the info from that |
