Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > DC Unlocker
Old 02-03-2020, 17:36   #16 (permalink)
Member: 2946079
Originally Posted by Namelocked View Post
Right click on your device in device manage, select uninstall, reconnect to pc, put it in manufacture mode, it should reinstall drivers automatically if hisuite is installed. I suspect other drivers were installed or there is something wrong with manufacture mode insertion on mobile itself.
I tried it, but as soon as I connect it again, it comes back in the same way (showing the device VKY-L09 with the orange exclamation mark)
It seems, that the drivers for the Phone in MTP Mode are correctly installed, but not for the manufacture mode. I have HiSuite installed and also the manual driver installation from Huawei... What else could I try?
Old 02-04-2020, 16:59   #17 (permalink)
Member: 2023196
Thanks Meter: 1,264
You can manually apply drivers for that line with exclamation mark.
The Following User Says Thank You to Namelocked For This Useful Post:
Old 02-05-2020, 08:00   #18 (permalink)
Member: 2946079
how can I do that? The driver file I downloaded from Huawei was an executable file (DriverSetup exe)
When I select the folder of it in the windows driver installing menu, it sais that there were no drivers found to install...
Old 02-05-2020, 08:57   #19 (permalink)
Member: 2023196
Thanks Meter: 1,264
You will have to find executed drivers that could be applied manually.
Old 02-05-2020, 09:52   #20 (permalink)
Member: 2946079
Ok, I found an extracted version of the drivers from hisuite now. But there are very many. Do you know wich one I should take? (thanks for your patience!)
androidwinusb cat
cdc-acm cat
cdc-acm inf
ew_ccgpfilter cat
ew_usbccgpfilter inf
ew_usbccgpfilter sys
hw_cdcacm cat
hw_cdcacm inf
hw_cdcacm sys
hw_cdcmdm inf
hw_goadb inf
hw_gohdb cat
hw_gohdb inf
hw_qumdm cat
hw_qumdm inf
hw_quser cat
hw_quser inf
hw_quusbmdm sys
hw_quusbnet cat
hw_quusbnet inf
hw_quusbnet sys
hw_usbdev cat
hw_usbdev inf
hw_usbdev sys
mtp inf
mtp64 cat
usbser sys
WdfCoInstaller01009 dll
winusbcoinstaller2 dll
WUDFUpdate_01009 dll
(I removed the dot in front of the file extensions, because this forum does not allow me to post things with a dot)
Old 02-05-2020, 17:05   #21 (permalink)
Member: 2023196
Thanks Meter: 1,264
You should simply apply whole folder with all drivers inside it, system should pick correct ones.
Old 02-05-2020, 18:22   #22 (permalink)
Member: 2946079
unfortunately it doesnt. It sais, that VKY-L09 couldnt be installed and that windows could not find drivers for it. Thats why I thought, I should install the drivers manually...
Any Idea, what else I could try?
I'd be really grateful!
Old 02-17-2020, 15:59   #23 (permalink)
Member: 2023196
Thanks Meter: 1,264
Can only try from different pc with different os. Or check how to disable driver signature check online on current windows.
Page generated in 0.50763 seconds with 7 queries
