04-10-2019, 02:33 | #1 (permalink) |
Registered User Join Date: May 2006 Location: Uzbekistan
Member: 284250 Status: Offline Thanks Meter: 5 | VKY P10 plus empty board flashing doesnt work 10.04.2019 4:23:05 Starting to write device in FASTBOOT mode... File to update: VKY-AL00_M00A066_Board_Software_general_7.0.0_r1_EMUI5 .1_05022AWK_testpoint.dgtks Device detected: COM81: HUAWEI USB COM 1.0 (COM81) Writing bootloader... Writing VKY-AL00_M00A066_Board_Software_general_7.0.0_r1_EMUI5 .1_05022AWK_testpoint_4.dtwork... Error writing Bootloader 10.04.2019 4:23:34 Writing device finished - INCOMPLETE But with OEMINFO update everything is Ok Device detected: COM81: HUAWEI USB COM 1.0 (COM81) BOOTLOADER File to update: Kirin960_T2_A7.0_V4 10.04.2019 4:30:19 Starting to write device... Writing bootloader... Writing Kirin960_T2_A7.0_V4_3.dtwork... Writing Kirin960_T2_A7.0_V4_4.dtwork... Writing Kirin960_T2_A7.0_V4_5.dtwork... Waiting for fastboot device... Device found: Y2J*** Looking for a device in fastboot mode Device found: Y2J*** Getting IMEI... Getting build number... Getting model ... Getting battery state... Getting backdoor info... Getting lock state info... Getting lock boot info... SN:Y2J*** IMEI:86*** IMEI1:86*** Build number: :VKY-L29C432B126 Model: VKY-L29 Battery state: 4051mv OEM lock state info: FB LockState: UNLOCKED USER LockState: LOCKED OEM get bootinfo: unlocked Software written 10.04.2019 4:30:53 Writing device finished OK Whats wrong? What is the problem? |
04-10-2019, 08:21 | #2 (permalink) |
Product Supporter Join Date: Sep 2013 Location: Lithuania, Kaunas
Member: 2023196 Status: Offline Thanks Meter: 1,891 | After flashing loader + oeminfo use full stock rom not board software. Board software does not flash because loader versions are mismatch. |
04-12-2019, 14:17 | #4 (permalink) |
Member: 284250 Status: Offline Thanks Meter: 5 | Solved Finally, solved the problem and unbricked my p10 plus after flashing with dc phoenix, and changed location (region) to l29 successfully. |
The Following User Says Thank You to ruslanuz For This Useful Post: |
