VOG-L29 error flashing i have vog-l29 working 100% and want to update android 10. when flashing by DC Phoenix it reach 30% then DC say error writing firmware. now phone just enter fastboot, tried to enter upgrade mode but in vain. how to solve please help phone info: https://drive.google.com/file/d/164w...ApSnh7YGi/view |
try to download stock firmware from emergency recovery |
try dload firmware link sent to you check your inbox Instructions This is the requirements 1- Upgrade with USB-OTG An OTG cable A USB drive (8GB at least) Formatted as NTFS or ExFat Also you can use an USB drive + USB C adapter Open the Zip and extract the dload folder on the pendrive - Turn off the P30 Pro - Connect the pendrive with the OTG cable - Now press the three buttons at the same time. - Volume + - Volume - - Power button. (The p30pro will light up and vibrate, keep the buttons pressed) Only when you see the blank screen and EMUI appears will you release the buttons. The flashing will start and lasts about 2 minutes. After flashing the P30 Pro will restart automatically |
let me know if you have any questions |
did you succeed to resolve your problem? |
p30 pro dead after flash with DC Phoenix i have vog-l29 working 100% and want to update android 10. when flashing by DC Phoenix it reach 30% then DC say error writing firmware. help me please:confused::confused::confused: |
firmware link https://androidhost.ru/2AV6 Instructions This is the requirements 1- Upgrade with USB-OTG An OTG cable A USB drive (8GB at least) Formatted as NTFS or ExFat Also you can use an USB drive + USB C adapter Open the Zip and extract the dload folder on the pendrive - Turn off the P30 Pro - Connect the pendrive with the OTG cable - Now press the three buttons at the same time. - Volume + - Volume - - Power button. (The p30pro will light up and vibrate, keep the buttons pressed) Only when you see the blank screen and EMUI appears will you release the buttons. The flashing will start and lasts about 2 minutes. After flashing the P30 Pro will restart automatically |
